Rpi 7" touch display slow response
I’m using Rpi4b 8GB ram with Rpi 7" display. Its running balena blocks browser and launch URL set at https://mfab-hmi-beta.vercel.app/. kiosk mode enabled GPU enabled, GPU memory allocated 512MB but still, the touch response is too slow. Kindly guide me on how to make it fast.
Initially, I tried with the 2GB ram version then tried with the 8GB ram version but nothing improved.
@omprakash have you tried setting the env var UDEV=1?
You might also have to adjust some configurations if using a touchscreen. Take a look at this balenaDash setup guide in order to see how you might need to configure your screen: GitHub - balenalabs/balena-dash: Build a Raspberry Pi based desktop dashboard for stats, photos, videos and more!
Thanks for your reply, i’m going to tryout these now.
