Thanks! Yes, I’m currently unranked and I got a key but you lost me with …“then add it to YOU APP” Can you pls explain?
yes the docs are not clear you need to get your BOINC key
and then enter it into https://dashboard.balena-cloud.com/apps/XXXXXX/service-envvars
your container will then restart but if you are 90% through a task i would wait until your 5% into a new task
Hey @fritz yeah that looks good to me. That’s a message from the client, which should periodically keep checking for more tasks
I have a fleet of idle pi’s A mix of 3 and 3B. I can fire up 10-15 if they will be of use. But with the memory limitation sounds like they may not be utilised much.
Hey @Stu6161 welcome to the forum! It’s a case of making the compute power available with these; if the researchers submitting tasks know there’s a whole load more devices available if they submit jobs with a lower memory requirement they may consider doing so. Although the 1GB devices may not have work right now it’s still great to have them ready on the network.
my pi3 (<1G) is contributing fine you can see its stats here
https://boinc.bakerlab.org/rosetta/show_host_detail.php?hostid=4282293
total credit to date 119
