Hi our current balena os works through several reboots when we’re initially testing but when left for a while overnight the Pi 0 2 w loses network connection and then on reboot we see:
Loading resinOS_uEnv.txtfrom mmc device 0 partition 1
Loading extra_uEnv.txt from mmc device 0 partition 1
0 bytes read in 2 ms (0 Bytes/s)
Import extra_uEnv.txt in environment
Loading bootcount.env from mmc device 0 partition 1
No bootcount.env fie. Setting bootcount=0 in environment
** Reading file would overwrite reserved memory **
Error: Bad gzipped ata
Bad Linux ARM64 Image magic!
SCRIPT FAILED: continuing...
Card did not respond to voltage select!
startig USB...
Bus usb@7e980000: scanning bus usb@7e980000 for devices... cannot reset port 1!?
cannot reset port 2!?
4 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
No ethrnet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrievig file: pxelinux.cfg/00000000
No ethernet found.
Retrievin file: pxelinux.cfg/0000000
No ethernet found.
Retrievingfile: pxelinux.cfg/000000
No ethernet found.
Retrieving fie: pxelinux.cfg/00000
No ethernet found.
Retrieving file: xelinux.cfg/0000
No ethernet found.
Retrieving file: pxeliux.cfg/000
No ethernet found.
Retrieving file: pxelinux.cf/00
No ethernet found.
Retrieving file: pxelinux.cfg/0
Noethernet found.
Retrieving file: pxelinux.cfg/default-arm-cm283x-rpi
No ethernet found.
Retrieving file: pxelinux.cf/default-arm-bcm283x
No ethernet found.
Retrieving file: pelinux.cfg/default-arm
No ethernet found.
Retrieving file:pxelinux.cfg/default
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
U-Boot>
and then we never manage to boot. Any help on this would be appreciated
