Was reading through the documentation to do a custom image build for ResinOS: https://resinos.io/docs/custombuild/#bake-your-own-image
Do you have a Docker image that you could share to setup the Yocto environment and run the builds?
Brice
Brice
We do have a docker image which can be found on dockerhub:
https://hub.docker.com/r/resin/yocto-build-env/
It’s built from a Dockerfile in this repo:
However it’s not really well documented or user friendly as it’s considered internal infrastructure. If you’d like to repurpose it for your own builds then we will do what we can to help though.
Awesome, thanks @willn!
@willn running into an error trying to run Docker directly, initially couldn’t run because “groupadd: GID ‘20’ already exists” so I’ve manually changed the group id but then I run into an issue later through the build.
docker run --rm -v $(pwd):/yocto/resin-board -v $(pwd)/shared-downloads:/yocto/shared-downloads -v $(pwd)/shared-sstate:/yocto/shared-sstate -e BUILDER_UID=$(id -u) -e BUILDER_GID=2000 --name yocto-build-raspberrypi3 --privileged resin/yocto-build-env /prepare-and-start.sh --log --machine "raspberrypi3" --shared-downloads /yocto/shared-downloads --shared-sstate /yocto/shared-sstate --rm-work
ERROR: quilt-native-0.64-r0 do_populate_sysroot: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:sstate_task_postfunc(d)
0003:
File: '/yocto/resin-board/build/../layers/poky/meta/classes/sstate.bbclass', lineno: 672, function: sstate_task_postfunc
0668:
0669:python sstate_task_postfunc () {
0670: shared_state = sstate_state_fromvars(d)
0671:
*** 0672: sstate_install(shared_state, d)
0673: for intercept in shared_state['interceptfuncs']:
0674: bb.build.exec_func(intercept, d, (d.getVar("WORKDIR", True),))
0675: omask = os.umask(0o002)
0676: if omask != 0o002:
File: '/yocto/resin-board/build/../layers/poky/meta/classes/sstate.bbclass', lineno: 276, function: sstate_install
0272:
0273: # Run the actual file install
0274: for state in ss['dirs']:
0275: if os.path.exists(state[1]):
*** 0276: oe.path.copyhardlinktree(state[1], state[2])
0277:
0278: for postinst in (d.getVar('SSTATEPOSTINSTFUNCS', True) or '').split():
0279: # All hooks should run in the SSTATE_INSTDIR
0280: bb.build.exec_func(postinst, d, (sstateinst,))
File: '/yocto/resin-board/build/../layers/poky/meta/lib/oe/path.py', lineno: 91, function: copyhardlinktree
0087: source = source + '%s/*' % src
0088: else:
0089: source = src
0090: cmd = 'cp -afl --preserve=xattr %s %s' % (source, dst)
*** 0091: subprocess.check_output(cmd, shell=True, stderr=subprocess.STDOUT)
0092: else:
0093: copytree(src, dst)
0094:
0095:def remove(path, recurse=True):
File: '/usr/lib/python3.5/subprocess.py', lineno: 626, function: check_output
0622: # empty string. That is maintained here for backwards compatibility.
0623: kwargs['input'] = '' if kwargs.get('universal_newlines', False) else b''
0624:
0625: return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
*** 0626: **kwargs).stdout
0627:
0628:
0629:class CompletedProcess(object):
0630: """A process that has finished running.
File: '/usr/lib/python3.5/subprocess.py', lineno: 708, function: run
0704: raise
0705: retcode = process.poll()
0706: if check and retcode:
0707: raise CalledProcessError(retcode, process.args,
*** 0708: output=stdout, stderr=stderr)
0709: return CompletedProcess(process.args, retcode, stdout, stderr)
0710:
0711:
0712:def list2cmdline(seq):
Exception: subprocess.CalledProcessError: Command 'cp -afl --preserve=xattr /yocto/resin-board/build/tmp/work/x86_64-linux/quilt-native/0.64-r0/sysroot-destdir/yocto/resin-board/build/tmp/sysroots/x86_64-linux/* /yocto/resin-board/build/tmp/sysroots/x86_64-linux' returned non-zero exit status 1
Subprocess output:
cp: cannot create hard link '/yocto/resin-board/build/tmp/sysroots/x86_64-linux/usr/share/quilt/compat/awk' to '/yocto/resin-board/build/tmp/work/x86_64-linux/quilt-native/0.64-r0/sysroot-destdir/yocto/resin-board/build/tmp/sysroots/x86_64-linux/usr/share/quilt/compat/awk': No such file or directory
ERROR: quilt-native-0.64-r0 do_populate_sysroot: Function failed: sstate_task_postfunc
ERROR: Logfile of failure stored in: /yocto/resin-board/build/tmp/work/x86_64-linux/quilt-native/0.64-r0/temp/log.do_populate_sysroot.1511
NOTE: recipe quilt-native-0.64-r0: task do_populate_sysroot: Failed
ERROR: Task (/yocto/resin-board/build/../layers/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb:do_populate_sysroot) failed with exit code '1'
Hi Brice,
you could use the resin-yocto-scripts repository and build using the above mentioned Docker image. Have a look at the available options for running it here:
@floion found out the issue, using mac and docker doesn’t play nicely with hardlinks and symlinks.
Glad to hear that. The above method I pointed could also let you build by using the docker container as pointed above, as the host environment and not depend on the OS installed on your development machine
@floion are you building on macos? I’ve tried the jenkins script initially and had the same issue with mounted volumes not playing well with hardlinks.
No, used it on Linux only
@floion I’m trying to build the Jetson TX2 version of resinos but running into issues. Any idea what’s going wrong please?
Cloned:
https://github.com/resin-os/resin-jetson-tx2
I’m running:
./resin-yocto-scripts/build/barys -m jetson-tx2 -d --resinio -r
And this is the error I get after few hours:
| Adding dependency on xproto-native
| NOTE: gcc-runtime exists in sysroot, skipping
| NOTE: glibc exists in sysroot, skipping
| NOTE: quilt-native exists in sysroot, skipping
| NOTE: linux-tegra exists in sysroot, skipping
| NOTE: gcc-cross-aarch64 exists in sysroot, skipping
| NOTE: linux-libc-headers exists in sysroot, skipping
| NOTE: libgcc exists in sysroot, skipping
| NOTE: automake-native exists in sysroot, skipping
| NOTE: binutils-cross-aarch64 exists in sysroot, skipping
| NOTE: zlib-native exists in sysroot, skipping
| NOTE: gnu-config-native exists in sysroot, skipping
| NOTE: libtool-native exists in sysroot, skipping
| NOTE: libmpc-native exists in sysroot, skipping
| NOTE: autoconf-native exists in sysroot, skipping
| NOTE: texinfo-dummy-native exists in sysroot, skipping
| NOTE: mpfr-native exists in sysroot, skipping
| NOTE: gmp-native exists in sysroot, skipping
| NOTE: bison-native exists in sysroot, skipping
| NOTE: flex-native exists in sysroot, skipping
| NOTE: xz-native exists in sysroot, skipping
| NOTE: m4-native exists in sysroot, skipping
| NOTE: gettext-minimal-native exists in sysroot, skipping
| DEBUG: sed -e 's:^[^/]*/:/home/Documents/resin-jetson-tx2/build/tmp/work/aarch64-poky-linux/tegra-binaries-prepare/28.1.0-r0/recipe-sysroot/:g' /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/jetson_tx2/depmodwrapper-cross/fixmepath | xargs sed -i -e 's:FIXMESTAGINGDIRTARGET:/home/Documents/resin-jetson-tx2/build/tmp/work/aarch64-poky-linux/tegra-binaries-prepare/28.1.0-r0/recipe-sysroot:g; s:FIXMESTAGINGDIRHOST:/home/Documents/resin-jetson-tx2/build/tmp/work/aarch64-poky-linux/tegra-binaries-prepare/28.1.0-r0/recipe-sysroot-native:g' -e 's:FIXME_COMPONENTS_DIR:/home/Documents/resin-jetson-tx2/build/tmp/sysroots-components:g' -e 's:FIXME_HOSTTOOLS_DIR:/home/Documents/resin-jetson-tx2/build/tmp/hosttools:g' -e 's:FIXME_PKGDATA_DIR:/home/Documents/resin-jetson-tx2/build/tmp/pkgdata/jetson-tx2:g'
| DEBUG: sed -e 's:^[^/]*/:/home/Documents/resin-jetson-tx2/build/tmp/work/aarch64-poky-linux/tegra-binaries-prepare/28.1.0-r0/recipe-sysroot-native/:g' /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/gtk-doc-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/pkgconfig-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/elfutils-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/python-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/glib-2.0-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/e2fsprogs-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/rpm-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/openssl-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/libpcre-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/python3-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/gettext-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/libpng-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/dbus-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/curl-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/ncurses-native/fixmepath /home/Documents/resin-jetson-tx2/build/tmp/sysroots-components/x86_64/nspr-native/fixmepath | xargs sed -i -e 's:FIXMESTAGINGDIRTARGET:/home/Documents/resin-jetson-tx2/build/tmp/work/aarch64-poky-linux/tegra-binaries-prepare/28.1.0-r0/recipe-sysroot:g; s:FIXMESTAGINGDIRHOST:/home/Documents/resin-jetson-tx2/build/tmp/work/aarch64-poky-linux/tegra-binaries-prepare/28.1.0-r0/recipe-sysroot-native:g' -e 's:FIXME_COMPONENTS_DIR:/home/Documents/resin-jetson-tx2/build/tmp/sysroots-components:g' -e 's:FIXME_HOSTTOOLS_DIR:/home/Documents/resin-jetson-tx2/build/tmp/hosttools:g' -e 's:FIXME_PKGDATA_DIR:/home/Documents/resin-jetson-tx2/build/tmp/pkgdata/jetson-tx2:g'
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_install
| cp: cannot stat '/home/Documents/resin-jetson-tx2/build/tmp/deploy/images/jetson-tx2/u-boot-dtb.bin': No such file or directory
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_install (log file is located at /home/Documents/resin-jetson-tx2/build/tmp/work/aarch64-poky-linux/tegra-binaries-prepare/28.1.0-r0/temp/log.do_install.27860)
ERROR: Task (/home/Documents/resin-jetson-tx2/build/../layers/meta-resin-jetson/recipes-support/tegra-binaries-prepare/tegra-binaries-prepare_28.1.0.bb:do_install) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2879 tasks of which 6 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 3 WARNING messages shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
[000005328][LOG]Build for jetson-tx2 failed. Check failed log in build/tmp/log/cooker/jetson-tx2 .
[000005328][LOG]If build for jetson-tx2 succeeded, final image should have been generated here:
[000005328][LOG] build/tmp/deploy/images/jetson-tx2/resin-image-flasher-jetson-tx2.resinos-img
[000005328][LOG]Done.
I missed this thread, sorry.
Are you still seeing these issues with the latest codebase?
@floion all good
still having that issue, I cloned the resinos/jetson-tx2 repo this morning and tried to build on Ubuntu 16.04 directly with the Yocto dependencies, npm and jq. (Had similar issues with the docker container).
What is the git clone command you are using?
I use:
git clone --recursive https://github.com/resin-os/resin-jetson-tx2
@telphan can you look into this please?
I have tested this and I run into no issues. Would you mind telling me the SHA of the repo that you are trying to build?
The SHA is 11ae421f8d3ccade9e2011d4780f0d103bd0967e, cloned from master 2 days ago.
I think I see the issue here. The tegra-binaries-prepare package needs to depend on virtual/bootloader, to ensure the existents of u-boot-dtb.bin.
A PR addressing this can be found: https://github.com/resin-os/resin-jetson-tx2/pull/25
Tried again today from SHA 55127a72c5bf826a9a8fe8a9db4055adbb5b8d2c (release_v2.7.4+rev1 branch) and still complains about the same issue:
| ERROR: Function failed: do_install (log file is located at /home/Documents/resin-jetson-tx2/build/tmp/work/aarch64-poky-linux/tegra-binaries-prepare/28.1.0-r0/temp/log.do_install.4636)
Full log from log.do_install.4636
https://pastebin.com/VJmq48XD
So I tried one more time with the jenkins_build.sh script and it works now, must be have been an issue with a dependency somewhere as I couldn’t get it to work on ubuntu directly last time.
Thanks again for your help @floion @willnewton and @telphan
