Resin Wifi Connect only works if I plug in ethernet first
Hey guys, I’ve been working with resin for about a week and am LOVING it. I’ve built out our prototype and am preparing to have them test it back at HQ.
My ideal workflow would be:
  1. Send them an *img.zip file that they can burn to the SD using Etcher
  2. Have it boot to https://github.com/resin-io/resin-wifi-connect and have them enter SSID/PSK
Right now I’ve been downloading the IMG file from the dashboard but it doesn’t seem to boot the portal until I connect it to wifi and it downloads a bunch of other stuff. These are the first few lines from the logs when it provisions for the first time:
27.02.18 18:44:26 (+0100) Applying configuration change {"RESIN_SUPERVISOR_NATIVE_LOGGER":"false"}
27.02.18 18:44:27 (+0100) Creating network 'default'
27.02.18 18:44:27 (+0100) Creating volume 'resin-data'
27.02.18 18:44:27 (+0100) Downloading image 'registry2.resin.io/v2/yadayada@sha256:yadayada'
I’ve tried combinations on the cli of resin init, resin-build, resin-deploy but it still hasn’t booted as I was hoping.
I have a feeling I’m fundamentally misunderstanding how the code/build/deploy process works and need to build the host and container images first locally so I can burn that IMG to an SD card but I’m a little stuck and hoping you guys can help.
Thanks in advance!
Dockerfile.template
FROM resin/%%RESIN_MACHINE_NAME%%-node:6-slim
RUN apt-get update && apt-get install -yq --no-install-recommends \
    curl cron iperf3 jq bc speedtest-cli python git wireless-tools vim dnsmasq \
#switch on systemd init system in container
ENV INITSYSTEM on
COPY . /usr/src/app
COPY package.json package.json
WORKDIR /usr/src/app
# pip install python deps from requirements.txt on the resin.io build server
RUN JOBS=MAX npm install --production --unsafe-perm && npm cache clean && rm -rf /tmp/*
RUN curl https://bootstrap.pypa.io/get-pip.py | python
RUN pip install git+https://github.com/sivel/speedtest-cli.git
RUN pip install pingparsing
# -- Start of resin-wifi-connect section -- #
# Set the device type environment variable using Dockerfile templates
ENV DEVICE_TYPE=%%RESIN_MACHINE_NAME%%
RUN curl https://api.github.com/repos/resin-io/resin-wifi-connect/releases/latest -s \
    | grep -hoP 'browser_download_url": "\K.*%%RESIN_ARCH%%\.tar\.gz' \
    | xargs -n1 curl -Ls \
    | tar -xvz -C /usr/src/app/
# -- End of resin-wifi-connect section -- #
# Provision device to Rails App
RUN sh provision.sh
# Load environment variables into crontab (not working - WIP)
# RUN (crontab -l ; cat /etc/docker.env)| crontab -
# Load cronjobs from crontab file
RUN (crontab -l; cat cronjobs)| crontab -
# start.sh will run when container starts up on the device
CMD ["bash", "start.sh"]
start.sh
#!/usr/bin/env bash
export DBUS_SYSTEM_BUS_ADDRESS=unix:path=/host/run/dbus/system_bus_socket
# Choose a condition for running WiFi Connect according to your use case:
# 1. Is there a default gateway?
# ip route | grep default
# 2. Is there Internet connectivity?
# nmcli -t g | grep full
# 3. Is there Internet connectivity via a google ping?
# wget --spider http://google.com 2>&1
# 4. Is there an active WiFi connection?
iwgetid -r
if [ $? -eq 0 ]; then
    printf 'Skipping WiFi Connect\n'
else
    printf 'Starting WiFi Connect\n'
    ./wifi-connect --portal-ssid sec-perfmon
fi
npm start
Props to @shaunmulligan - I shot him an email with this link and he suggested the following:
resin preload resin-perfmon-2.12.3+rev1-dev-v7.1.14.img
I then burnt the same file “resin preload resin-perfmon-2.12.3+rev1-dev-v7.1.14.img” to my SD card and it booted as I was hoping!
Perhaps it would make sense to update the instructions on https://github.com/resin-io/resin-wifi-connect so complete noobs can get this up and running!
Thanks guys :slight_smile:
@majorz Perhaps we want to mention this use case on the wifi-connect repo?
I included this forum thread in a pending WiFi Connect ticket about improving the docs for running on top of resinOS.
