I am running the BelenaCloud with Screenly OSE.
I got everything working but the issue is when I modify the /etc/hosts file to add my internal ip & DNS for a page that is not accessible outside my network it works fine and displays my pages but if I shutdown or reboot the Raspberry with Resin.IO after the reboot the host file defaults back to the original.
I use the Resin.IO shell inside my cloud and works fine when I set the time zone etc and those settings do not reset.
I use the command : sudo nano /etc/hosts and add my IP & DNS under the local host and then save.
Not sure what I am doing wrong in this scenario?
