I am trying to build balena-jetson for v2.105.2+rev3, but I keep getting an error that I don’t know how to debug.
I ran ./balena-yocto-scripts/build/barys -m jetson-xavier-nx-devkit-emmc, and after some time got
WARNING: linux-tegra-4.9.253+gitAUTOINC+ad2fc41d9a-r0 do_kernel_resin_checkconfig: Checking for CONFIG_NFS_V3=y in the kernel configs failed for nfsfs.
WARNING: linux-tegra-4.9.253+gitAUTOINC+ad2fc41d9a-r0 do_kernel_resin_checkconfig: Checking for CONFIG_NFS_V4=y in the kernel configs failed for nfsfs.
WARNING: linux-tegra-4.9.253+gitAUTOINC+ad2fc41d9a-r0 do_kernel_resin_checkconfig: Checking for CONFIG_NFS_V2=y in the kernel configs failed for nfsfs.
WARNING: linux-tegra-4.9.253+gitAUTOINC+ad2fc41d9a-r0 do_kernel_resin_checkconfig: Checking for CONFIG_BACKLIGHT_CLASS_DEVICE=m in the kernel configs failed for backlight.
ERROR: docker-disk-2.105.2+rev3-r0 do_deploy: ExecutionError('/data/balena-jetson/build/tmp/work/jetson_xavier_nx_devkit_emmc-poky-linux/docker-disk/2.105.2+rev3-r0/temp/run.do_deploy.4029959', 1, None, None)
ERROR: Logfile of failure stored in: /data/balena-jetson/build/tmp/work/jetson_xavier_nx_devkit_emmc-poky-linux/docker-disk/2.105.2+rev3-r0/temp/log.do_deploy.4029959
Log data follows:
| DEBUG: Executing python function sstate_task_prefunc
| DEBUG: Python function sstate_task_prefunc finished
| DEBUG: Executing shell function do_deploy
| install: cannot stat '/data/balena-jetson/build/tmp/work/jetson_xavier_nx_devkit_emmc-poky-linux/docker-disk/2.105.2+rev3-r0/build/resin-data.img': No such file or directory
| WARNING: exit code 1 from a shell command.
ERROR: Task (/data/balena-jetson/build/../layers/meta-balena/meta-balena-common/recipes-containers/docker-disk/docker-disk.bb:do_deploy) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3099 tasks of which 0 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 30 WARNING messages shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
[000002494][LOG]Build for jetson-xavier-nx-devkit-emmc failed. Check failed log in build/tmp/log/cooker/jetson-xavier-nx-devkit-emmc .
[000002494][LOG]If build for jetson-xavier-nx-devkit-emmc succeeded, final image should have been generated here:
[000002494][LOG] build/tmp/deploy/images/jetson-xavier-nx-devkit-emmc/balena-image-jetson-xavier-nx-devkit-emmc.balenaos-img
[000002494][LOG]Done.
Indeed /data/balena-jetson/build/tmp/work/jetson_xavier_nx_devkit_emmc-poky-linux/docker-disk/2.105.2+rev3-r0/build/resin-data.img does not exist, but I am not sure where to look for an error description. In the logs I see the same as above.
Any help is appreciated, thank you!
Carlos
