Resetting container data from SD card access
Hi there!
Assuming I have no access to the balena server, how can I reset the containers on a device just from SD card access? I tried deleting the data inside the containers folder of resin-data with no luck. In princple, I’d like to “reset” a device without the option of reflashing but only modifying the SD card.
Julien
What do you mean by “reset the containers” exactly? Are you trying to delete all the volumes/networks/images and re-create them again or something else? In general, you don’t need access to balena cloud to log in to your device, you can log in using balena cli from your terminal: balena CLI Documentation - Balena Documentation
