Balena Cloud RPI 3B+ device stuck for more than 24hours in update state.
Error: " Request error: tunneling socket could not be established, statusCode=500" when trying to reboot or restart container.
Here are the logs from dmesg:
[Thu Mar 19 08:50:27 2020] Booting Linux on physical CPU 0x0
[Thu Mar 19 08:50:27 2020] Linux version 4.19.71 (oe-user@oe-host) (gcc version 8.3.0 (GCC)) #1 SMP Fri Jan 31 09:22:57 UTC 2020
[Thu Mar 19 08:50:27 2020] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[Thu Mar 19 08:50:27 2020] CPU: div instructions available: patching division code
[Thu Mar 19 08:50:27 2020] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[Thu Mar 19 08:50:27 2020] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[Thu Mar 19 08:50:27 2020] Memory policy: Data cache writealloc
[Thu Mar 19 08:50:27 2020] cma: Reserved 8 MiB at 0x3dc00000
[Thu Mar 19 08:50:27 2020] On node 0 totalpages: 255488
[Thu Mar 19 08:50:27 2020] Normal zone: 2246 pages used for memmap
[Thu Mar 19 08:50:27 2020] Normal zone: 0 pages reserved
[Thu Mar 19 08:50:27 2020] Normal zone: 255488 pages, LIFO batch:63
[Thu Mar 19 08:50:27 2020] random: get_random_bytes called from start_kernel+0xb0/0x4b8 with crng_init=0
[Thu Mar 19 08:50:27 2020] percpu: Embedded 17 pages/cpu s39564 r8192 d21876 u69632
[Thu Mar 19 08:50:27 2020] pcpu-alloc: s39564 r8192 d21876 u69632 alloc=17*4096
[Thu Mar 19 08:50:27 2020] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[Thu Mar 19 08:50:27 2020] Built 1 zonelists, mobility grouping on. Total pages: 253242
[Thu Mar 19 08:50:27 2020] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 dwc_otg.lpm_enable=0 console=null rootfstype=ext4 rootwait vt.global_cursor_default=0 root=PARTUUID=34586054-02 rootwait
[Thu Mar 19 08:50:27 2020] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[Thu Mar 19 08:50:27 2020] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[Thu Mar 19 08:50:27 2020] Memory: 983636K/1021952K available (8192K kernel code, 655K rwdata, 2352K rodata, 7168K init, 828K bss, 30124K reserved, 8192K cma-reserved)
[Thu Mar 19 08:50:27 2020] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbe800000 - 0xff800000 (1040 MB)
lowmem : 0x80000000 - 0xbe600000 ( 998 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x(ptrval) - 0x(ptrval) (9184 kB)
.init : 0x(ptrval) - 0x(ptrval) (7168 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 656 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 829 kB)
[Thu Mar 19 08:50:27 2020] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[Thu Mar 19 08:50:27 2020] ftrace: allocating 28726 entries in 85 pages
[Thu Mar 19 08:50:27 2020] rcu: Hierarchical RCU implementation.
[Thu Mar 19 08:50:27 2020] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[Thu Mar 19 08:50:27 2020] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[Thu Mar 19 08:50:27 2020] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[Thu Mar 19 08:50:27 2020] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[Thu Mar 19 08:50:27 2020] Switching to timer-based delay loop, resolution 52ns
[Thu Mar 19 08:50:27 2020] Console: colour dummy device 80x30
[Thu Mar 19 08:50:27 2020] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[Thu Mar 19 08:50:27 2020] pid_max: default: 32768 minimum: 301
[Thu Mar 19 08:50:27 2020] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[Thu Mar 19 08:50:27 2020] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[Thu Mar 19 08:50:27 2020] CPU: Testing write buffer coherency: ok
[Thu Mar 19 08:50:27 2020] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[Thu Mar 19 08:50:27 2020] Setting up static identity map for 0x100000 - 0x10003c
[Thu Mar 19 08:50:27 2020] rcu: Hierarchical SRCU implementation.
[Thu Mar 19 08:50:27 2020] smp: Bringing up secondary CPUs ...
[Thu Mar 19 08:50:27 2020] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[Thu Mar 19 08:50:27 2020] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[Thu Mar 19 08:50:27 2020] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[Thu Mar 19 08:50:27 2020] smp: Brought up 1 node, 4 CPUs
[Thu Mar 19 08:50:27 2020] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[Thu Mar 19 08:50:27 2020] CPU: All CPU(s) started in HYP mode.
[Thu Mar 19 08:50:27 2020] CPU: Virtualization extensions available.
[Thu Mar 19 08:50:27 2020] devtmpfs: initialized
[Thu Mar 19 08:50:27 2020] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[Thu Mar 19 08:50:27 2020] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[Thu Mar 19 08:50:27 2020] futex hash table entries: 1024 (order: 4, 65536 bytes)
[Thu Mar 19 08:50:27 2020] pinctrl core: initialized pinctrl subsystem
[Thu Mar 19 08:50:27 2020] NET: Registered protocol family 16
[Thu Mar 19 08:50:27 2020] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[Thu Mar 19 08:50:27 2020] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[Thu Mar 19 08:50:27 2020] hw-breakpoint: maximum watchpoint size is 8 bytes.
[Thu Mar 19 08:50:27 2020] Serial: AMBA PL011 UART driver
[Thu Mar 19 08:50:27 2020] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[Thu Mar 19 08:50:27 2020] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[Thu Mar 19 08:50:27 2020] SCSI subsystem initialized
[Thu Mar 19 08:50:27 2020] usbcore: registered new interface driver usbfs
[Thu Mar 19 08:50:27 2020] usbcore: registered new interface driver hub
[Thu Mar 19 08:50:27 2020] usbcore: registered new device driver usb
[Thu Mar 19 08:50:27 2020] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-28 15:08, variant start_cd
[Thu Mar 19 08:50:27 2020] raspberrypi-firmware soc:firmware: Firmware hash is 31098ceed842ca10c8ffd02ffe3640bf6c0190b4
[Thu Mar 19 08:50:27 2020] clocksource: Switched to clocksource arch_sys_counter
[Thu Mar 19 08:50:27 2020] VFS: Disk quotas dquot_6.6.0
[Thu Mar 19 08:50:27 2020] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[Thu Mar 19 08:50:27 2020] FS-Cache: Loaded
[Thu Mar 19 08:50:27 2020] CacheFiles: Loaded
[Thu Mar 19 08:50:27 2020] NET: Registered protocol family 2
[Thu Mar 19 08:50:27 2020] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[Thu Mar 19 08:50:27 2020] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[Thu Mar 19 08:50:27 2020] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[Thu Mar 19 08:50:27 2020] TCP: Hash tables configured (established 8192 bind 8192)
[Thu Mar 19 08:50:27 2020] UDP hash table entries: 512 (order: 2, 16384 bytes)
[Thu Mar 19 08:50:27 2020] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[Thu Mar 19 08:50:27 2020] RPC: Registered named UNIX socket transport module.
[Thu Mar 19 08:50:27 2020] RPC: Registered udp transport module.
[Thu Mar 19 08:50:27 2020] RPC: Registered tcp transport module.
[Thu Mar 19 08:50:27 2020] RPC: Registered tcp NFSv4.1 backchannel transport module.
[Thu Mar 19 08:50:27 2020] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[Thu Mar 19 08:50:27 2020] Initialise system trusted keyrings
[Thu Mar 19 08:50:27 2020] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[Thu Mar 19 08:50:27 2020] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[Thu Mar 19 08:50:27 2020] FS-Cache: Netfs 'nfs' registered for caching
[Thu Mar 19 08:50:27 2020] NFS: Registering the id_resolver key type
[Thu Mar 19 08:50:27 2020] Key type id_resolver registered
[Thu Mar 19 08:50:27 2020] Key type id_legacy registered
[Thu Mar 19 08:50:27 2020] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[Thu Mar 19 08:50:27 2020] aufs 4.19.17+-20190211
[Thu Mar 19 08:50:27 2020] Key type asymmetric registered
[Thu Mar 19 08:50:27 2020] Asymmetric key parser 'x509' registered
[Thu Mar 19 08:50:27 2020] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[Thu Mar 19 08:50:27 2020] io scheduler noop registered
[Thu Mar 19 08:50:27 2020] io scheduler deadline registered
[Thu Mar 19 08:50:27 2020] io scheduler cfq registered (default)
[Thu Mar 19 08:50:27 2020] io scheduler mq-deadline registered
[Thu Mar 19 08:50:27 2020] io scheduler kyber registered
[Thu Mar 19 08:50:27 2020] bcm2708_fb soc:fb: FB found 1 display(s)
[Thu Mar 19 08:50:27 2020] Console: switching to colour frame buffer device 82x26
[Thu Mar 19 08:50:27 2020] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[Thu Mar 19 08:50:27 2020] bcm2835-rng 3f104000.rng: hwrng registered
[Thu Mar 19 08:50:27 2020] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
[Thu Mar 19 08:50:27 2020] vc-sm: Videocore shared memory driver
[Thu Mar 19 08:50:27 2020] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[Thu Mar 19 08:50:27 2020] brd: module loaded
[Thu Mar 19 08:50:27 2020] loop: module loaded
[Thu Mar 19 08:50:27 2020] Loading iSCSI transport class v2.0-870.
[Thu Mar 19 08:50:27 2020] libphy: Fixed MDIO Bus: probed
[Thu Mar 19 08:50:27 2020] tun: Universal TUN/TAP device driver, 1.6
[Thu Mar 19 08:50:27 2020] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[Thu Mar 19 08:50:27 2020] dwc_otg 3f980000.usb: base=(ptrval)
[Thu Mar 19 08:50:27 2020] Core Release: 2.80a
[Thu Mar 19 08:50:27 2020] Setting default values for core params
[Thu Mar 19 08:50:27 2020] Finished setting default values for core params
[Thu Mar 19 08:50:27 2020] Using Buffer DMA mode
[Thu Mar 19 08:50:27 2020] Periodic Transfer Interrupt Enhancement - disabled
[Thu Mar 19 08:50:27 2020] Multiprocessor Interrupt Enhancement - disabled
[Thu Mar 19 08:50:27 2020] OTG VER PARAM: 0, OTG VER FLAG: 0
[Thu Mar 19 08:50:27 2020] Dedicated Tx FIFOs mode
[Thu Mar 19 08:50:27 2020] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bdd14000 dma = 0xfdd14000 len=9024
[Thu Mar 19 08:50:27 2020] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[Thu Mar 19 08:50:27 2020] dwc_otg: Microframe scheduler enabled
[Thu Mar 19 08:50:27 2020] WARN::hcd_init_fiq:457: FIQ on core 1
[Thu Mar 19 08:50:27 2020] WARN::hcd_init_fiq:458: FIQ ASM at 8068b1bc length 36
[Thu Mar 19 08:50:27 2020] WARN::hcd_init_fiq:497: MPHI regs_base at be810000
[Thu Mar 19 08:50:27 2020] dwc_otg 3f980000.usb: DWC OTG Controller
[Thu Mar 19 08:50:27 2020] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[Thu Mar 19 08:50:27 2020] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[Thu Mar 19 08:50:27 2020] Init: Port Power? op_state=1
[Thu Mar 19 08:50:27 2020] Init: Power Port (0)
[Thu Mar 19 08:50:27 2020] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[Thu Mar 19 08:50:27 2020] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[Thu Mar 19 08:50:27 2020] usb usb1: Product: DWC OTG Controller
[Thu Mar 19 08:50:27 2020] usb usb1: Manufacturer: Linux 4.19.71 dwc_otg_hcd
[Thu Mar 19 08:50:27 2020] usb usb1: SerialNumber: 3f980000.usb
[Thu Mar 19 08:50:27 2020] hub 1-0:1.0: USB hub found
[Thu Mar 19 08:50:27 2020] hub 1-0:1.0: 1 port detected
[Thu Mar 19 08:50:27 2020] dwc_otg: FIQ enabled
[Thu Mar 19 08:50:27 2020] dwc_otg: NAK holdoff enabled
[Thu Mar 19 08:50:27 2020] dwc_otg: FIQ split-transaction FSM enabled
[Thu Mar 19 08:50:27 2020] Module dwc_common_port init
[Thu Mar 19 08:50:27 2020] usbcore: registered new interface driver usb-storage
[Thu Mar 19 08:50:27 2020] mousedev: PS/2 mouse device common for all mice
[Thu Mar 19 08:50:27 2020] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[Thu Mar 19 08:50:27 2020] bcm2835-cpufreq: min=600000 max=1400000
[Thu Mar 19 08:50:27 2020] sdhci: Secure Digital Host Controller Interface driver
[Thu Mar 19 08:50:27 2020] sdhci: Copyright(c) Pierre Ossman
[Thu Mar 19 08:50:27 2020] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[Thu Mar 19 08:50:27 2020] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[Thu Mar 19 08:50:27 2020] sdhci-pltfm: SDHCI platform and OF driver helper
[Thu Mar 19 08:50:27 2020] ledtrig-cpu: registered to indicate activity on CPUs
[Thu Mar 19 08:50:27 2020] hidraw: raw HID events driver (C) Jiri Kosina
[Thu Mar 19 08:50:27 2020] usbcore: registered new interface driver usbhid
[Thu Mar 19 08:50:27 2020] usbhid: USB HID core driver
[Thu Mar 19 08:50:27 2020] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[Thu Mar 19 08:50:27 2020] [vc_sm_connected_init]: start
[Thu Mar 19 08:50:27 2020] vc_vchi_sm_init: failed to open VCHI service (-1)
[Thu Mar 19 08:50:27 2020] [vc_sm_connected_init]: failed to initialize shared memory service
[Thu Mar 19 08:50:27 2020] [vc_sm_connected_init]: end - returning -1
[Thu Mar 19 08:50:27 2020] Initializing XFRM netlink socket
[Thu Mar 19 08:50:27 2020] NET: Registered protocol family 10
[Thu Mar 19 08:50:27 2020] Segment Routing with IPv6
[Thu Mar 19 08:50:27 2020] NET: Registered protocol family 17
[Thu Mar 19 08:50:27 2020] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[Thu Mar 19 08:50:27 2020] Key type dns_resolver registered
[Thu Mar 19 08:50:27 2020] Registering SWP/SWPB emulation handler
[Thu Mar 19 08:50:27 2020] registered taskstats version 1
[Thu Mar 19 08:50:27 2020] Loading compiled-in X.509 certificates
[Thu Mar 19 08:50:27 2020] uart-pl011 3f201000.serial: cts_event_workaround enabled
[Thu Mar 19 08:50:27 2020] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[Thu Mar 19 08:50:27 2020] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[Thu Mar 19 08:50:27 2020] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[Thu Mar 19 08:50:27 2020] sdhost: log_buf @ (ptrval) (fdd13000)
[Thu Mar 19 08:50:27 2020] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[Thu Mar 19 08:50:27 2020] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[Thu Mar 19 08:50:27 2020] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[Thu Mar 19 08:50:27 2020] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[Thu Mar 19 08:50:27 2020] of_cfs_init
[Thu Mar 19 08:50:27 2020] of_cfs_init: OK
[Thu Mar 19 08:50:27 2020] Warning: unable to open an initial console.
[Thu Mar 19 08:50:27 2020] Freeing unused kernel memory: 7168K
[Thu Mar 19 08:50:27 2020] Run /init as init process
[Thu Mar 19 08:50:27 2020] mmc0: host does not support reading read-only switch, assuming write-enable
[Thu Mar 19 08:50:27 2020] mmc0: new high speed SDHC card at address 0007
[Thu Mar 19 08:50:27 2020] mmcblk0: mmc0:0007 SD16G 14.6 GiB
[Thu Mar 19 08:50:27 2020] random: fast init done
[Thu Mar 19 08:50:27 2020] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[Thu Mar 19 08:50:27 2020] mmc1: new high speed SDIO card at address 0001
[Thu Mar 19 08:50:27 2020] Indeed it is in host mode hprt0 = 00021501
[Thu Mar 19 08:50:28 2020] usb 1-1: new high-speed USB device number 2 using dwc_otg
[Thu Mar 19 08:50:28 2020] Indeed it is in host mode hprt0 = 00001101
[Thu Mar 19 08:50:28 2020] udevd[284]: Starting version 241-166-g511646b+
[Thu Mar 19 08:50:28 2020] udevd[285]: Specified group 'render' unknown
[Thu Mar 19 08:50:28 2020] udevd[285]: Specified group 'kvm' unknown
[Thu Mar 19 08:50:28 2020] udevd[291]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
[Thu Mar 19 08:50:28 2020] udevd[296]: Process '/lib/systemd/systemd-vconsole-setup' failed with exit code 1.
[Thu Mar 19 08:50:28 2020] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[Thu Mar 19 08:50:28 2020] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[Thu Mar 19 08:50:28 2020] hub 1-1:1.0: USB hub found
[Thu Mar 19 08:50:28 2020] hub 1-1:1.0: 4 ports detected
[Thu Mar 19 08:50:28 2020] udevd[288]: Process '/lib/udev/resin_update_state_probe /dev/mmcblk0p3' failed with exit code 1.
[Thu Mar 19 08:50:28 2020] udevd[296]: Process '/lib/udev/resin_update_state_probe /dev/mmcblk0p2' failed with exit code 1.
[Thu Mar 19 08:50:28 2020] CP437: Invalid argument
[Thu Mar 19 08:50:28 2020] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[Thu Mar 19 08:50:28 2020] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[Thu Mar 19 08:50:28 2020] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[Thu Mar 19 08:50:28 2020] hub 1-1.1:1.0: USB hub found
[Thu Mar 19 08:50:28 2020] hub 1-1.1:1.0: 3 ports detected
[Thu Mar 19 08:50:28 2020] fsck.fat 4.1 (2017-01-24)
0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Automatically removing dirty bit.
Performing changes.
/dev/disk/by-label/resin-boot: 166 files, 16418/80628 clusters
[Thu Mar 19 08:50:28 2020] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[Thu Mar 19 08:50:29 2020] resin-rootA: recovering journal
[Thu Mar 19 08:50:29 2020] usb 1-1.2: New USB device found, idVendor=0483, idProduct=5740, bcdDevice= 2.00
[Thu Mar 19 08:50:29 2020] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Thu Mar 19 08:50:29 2020] usb 1-1.2: Product: Volta COM Port
[Thu Mar 19 08:50:29 2020] usb 1-1.2: Manufacturer: OffgridElectric
[Thu Mar 19 08:50:29 2020] usb 1-1.2: SerialNumber: 00000000001A
[Thu Mar 19 08:50:29 2020] usb 1-1.1.2: new full-speed USB device number 5 using dwc_otg
[Thu Mar 19 08:50:29 2020] usb 1-1.1.2: New USB device found, idVendor=0483, idProduct=5740, bcdDevice= 2.00
[Thu Mar 19 08:50:29 2020] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Thu Mar 19 08:50:29 2020] usb 1-1.1.2: Product: Volta COM Port
[Thu Mar 19 08:50:29 2020] usb 1-1.1.2: Manufacturer: OffgridElectric
[Thu Mar 19 08:50:29 2020] usb 1-1.1.2: SerialNumber: 00000000001A
[Thu Mar 19 08:50:29 2020] usb 1-1.1.3: new full-speed USB device number 6 using dwc_otg
[Thu Mar 19 08:50:29 2020] usb 1-1.1.3: New USB device found, idVendor=0483, idProduct=5740, bcdDevice= 2.00
[Thu Mar 19 08:50:29 2020] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[Thu Mar 19 08:50:29 2020] usb 1-1.1.3: Product: Volta COM Port
[Thu Mar 19 08:50:29 2020] usb 1-1.1.3: Manufacturer: OffgridElectric
[Thu Mar 19 08:50:29 2020] usb 1-1.1.3: SerialNumber: 00000000001A
[Thu Mar 19 08:50:29 2020] usb 1-1.1.1: new high-speed USB device number 7 using dwc_otg
[Thu Mar 19 08:50:30 2020] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[Thu Mar 19 08:50:30 2020] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[Thu Mar 19 08:50:32 2020] resin-rootA: clean, 7364/39936 files, 228323/319488 blocks
[Thu Mar 19 08:50:32 2020] resin-rootB: clean, 11/39936 files, 15349/319488 blocks
[Thu Mar 19 08:50:32 2020] udevd[289]: Process '/lib/udev/resin_update_state_probe /dev/mmcblk0p2' failed with exit code 1.
[Thu Mar 19 08:50:32 2020] resin-state: recovering journal
[Thu Mar 19 08:50:33 2020] udevd[289]: Process '/lib/udev/resin_update_state_probe /dev/mmcblk0p3' failed with exit code 1.
[Thu Mar 19 08:50:33 2020] resin-state: clean, 70/5136 files, 1908/20480 blocks
[Thu Mar 19 08:50:34 2020] udevd[296]: Process '/lib/udev/resin_update_state_probe /dev/mmcblk0p3' failed with exit code 1.
[Thu Mar 19 08:50:34 2020] udevd[295]: Process '/lib/udev/resin_update_state_probe /dev/mmcblk0p2' failed with exit code 1.
[Thu Mar 19 08:50:34 2020] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[Thu Mar 19 08:50:35 2020] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[Thu Mar 19 08:50:35 2020] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[Thu Mar 19 08:50:35 2020] switch_root: can't open '/dev/console': No such device
[Thu Mar 19 08:50:35 2020] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[Thu Mar 19 08:50:35 2020] aufs au_opts_verify:1609:init[1]: dirperm1 breaks the protection by the permission bits on the lower branch
[Thu Mar 19 08:50:35 2020] time="1970-01-01T00:00:08Z" level=warning msg="Couldn't run auplink before unmount /tmp/docker-aufs-union220678268" error="exec: \"auplink\": executable file not found in $PATH" storage-driver=aufs
[Thu Mar 19 08:50:38 2020] systemd[1]: System time before build time, advancing clock.
[Thu Mar 19 08:50:39 2020] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[Thu Mar 19 08:50:39 2020] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[Thu Mar 19 08:50:39 2020] systemd[1]: /lib/systemd/system/chronyd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/chrony/chronyd.pid \xe2\x86\x92 /run/chrony/chronyd.pid; please update the unit file accordingly.
[Thu Mar 19 08:50:39 2020] random: systemd: uninitialized urandom read (16 bytes read)
[Thu Mar 19 08:52:11 2020] random: crng init done
[Thu Mar 19 08:52:11 2020] random: 7 urandom warning(s) missed due to ratelimiting
[Thu Mar 19 08:53:16 2020] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[Thu Mar 19 08:53:17 2020] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[Thu Mar 19 08:53:17 2020] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[Thu Mar 19 08:53:17 2020] [vc_sm_connected_init]: start
[Thu Mar 19 08:53:17 2020] vc_sm_cma_vchi_init: failed to open VCHI service (-1)
[Thu Mar 19 08:53:17 2020] [vc_sm_connected_init]: failed to initialize shared memory service
[Thu Mar 19 08:53:17 2020] media: Linux media interface: v0.10
[Thu Mar 19 08:53:17 2020] videodev: Linux video capture interface: v2.00
[Thu Mar 19 08:53:17 2020] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[Thu Mar 19 08:53:17 2020] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[Thu Mar 19 08:53:17 2020] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
[Thu Mar 19 08:53:17 2020] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[Thu Mar 19 08:53:18 2020] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[Thu Mar 19 08:53:18 2020] bcm2835_audio soc:audio: card created with 8 channels
[Thu Mar 19 08:53:18 2020] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[Thu Mar 19 08:53:18 2020] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
[Thu Mar 19 08:53:18 2020] cdc_acm 1-1.1.2:1.0: ttyACM1: USB ACM device
[Thu Mar 19 08:53:18 2020] cdc_acm 1-1.1.3:1.0: ttyACM2: USB ACM device
[Thu Mar 19 08:53:18 2020] usbcore: registered new interface driver cdc_acm
[Thu Mar 19 08:53:18 2020] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[Thu Mar 19 08:53:18 2020] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[Thu Mar 19 08:53:18 2020] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[Thu Mar 19 08:53:18 2020] cfg80211: failed to load regulatory.db
[Thu Mar 19 08:53:18 2020] brcmfmac: F1 signature read @0x18000000=0x15264345
[Thu Mar 19 08:53:18 2020] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[Thu Mar 19 08:53:18 2020] usbcore: registered new interface driver brcmfmac
[Thu Mar 19 08:53:18 2020] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[Thu Mar 19 08:53:18 2020] libphy: lan78xx-mdiobus: probed
[Thu Mar 19 08:53:19 2020] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[Thu Mar 19 08:53:19 2020] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: May 2 2019 02:46:17 version 7.45.189 (r714228 CY) FWID 01-e1db26e2
[Thu Mar 19 08:53:19 2020] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[Thu Mar 19 08:53:19 2020] usbcore: registered new interface driver lan78xx
[Thu Mar 19 08:53:20 2020] i2c /dev entries driver
[Thu Mar 19 08:53:22 2020] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[Thu Mar 19 08:53:22 2020] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[Thu Mar 19 08:53:22 2020] brcmfmac: power management disabled
[Thu Mar 19 08:53:26 2020] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[Thu Mar 19 08:53:26 2020] brcmfmac: power management disabled
[Thu Mar 19 08:53:27 2020] Bridge firewalling registered
[Thu Mar 19 08:53:28 2020] IPv6: ADDRCONF(NETDEV_UP): br-529c4b92abd5: link is not ready
[Thu Mar 19 08:53:28 2020] IPv6: ADDRCONF(NETDEV_UP): supervisor0: link is not ready
[Thu Mar 19 08:53:28 2020] IPv6: ADDRCONF(NETDEV_UP): balena0: link is not ready
[Thu Mar 19 08:53:32 2020] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Here are the logs from journalctl.
Mar 19 08:39:37 a98c25b bd7d710a7660[2287]: [1B blob data]
Mar 19 08:39:51 a98c25b balenad[2287]: time="2020-03-19T08:39:51.922640467Z" level=info msg="shim reaped" id=f34e104e26279e5d790115335198915f81969448461821a33c31ff8d4a60106b
Mar 19 08:39:51 a98c25b balenad[2287]: time="2020-03-19T08:39:51.928848014Z" level=error msg="failed to delete bundle" error="rename /var/lib/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/f34e104e26279e5d790115335198915f81969448461821a33c31ff8d4a60106b /var/lib/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/.f34e104e26279e5d790115335198915f81969448461821a33c31ff8d4a60106b: file exists"
Mar 19 08:39:51 a98c25b balenad[2287]: time="2020-03-19T08:39:51.929753995Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Mar 19 08:40:22 a98c25b balenad[2287]: time="2020-03-19T08:40:22.028036237Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/f34e104e26279e5d790115335198915f81969448461821a33c31ff8d4a60106b/shim.sock debug=false pid=3590
Mar 19 08:40:23 a98c25b f34e104e2627[2287]: Starting system message bus: dbus.
Mar 19 08:40:23 a98c25b f34e104e2627[2287]: * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
Mar 19 08:40:23 a98c25b f34e104e2627[2287]: ...done.
Mar 19 08:40:41 a98c25b balenad[2287]: time="2020-03-19T08:40:41.203526006Z" level=info msg="Container f34e104e26279e5d790115335198915f81969448461821a33c31ff8d4a60106b failed to exit within 10 seconds of signal 15 - using the force"
Mar 19 08:40:42 a98c25b balenad[2287]: time="2020-03-19T08:40:42.201356995Z" level=info msg="shim reaped" id=f34e104e26279e5d790115335198915f81969448461821a33c31ff8d4a60106b
Mar 19 08:40:42 a98c25b balenad[2287]: time="2020-03-19T08:40:42.207671676Z" level=error msg="failed to delete bundle" error="rename /var/lib/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/f34e104e26279e5d790115335198915f81969448461821a33c31ff8d4a60106b /var/lib/docker/containerd/daemon/io.containerd.runtime.v1.linux/moby/.f34e104e26279e5d790115335198915f81969448461821a33c31ff8d4a60106b: file exists"
Mar 19 08:40:42 a98c25b balenad[2287]: time="2020-03-19T08:40:42.208530418Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
