This may be a dumb question, but how can I remove the WiFi configuration on a device in order to test wifi-connect?
I was able to remove the configured WiFi connections using nmcli from the host:
Welcome to balenaOS
root@1c72c55:~# nmcli connection show
NAME UUID TYPE DEVICE
resin-wifi-01 a58e405d-fdc2-3649-9339-5bbaea740c76 wifi wlan0
supervisor0 148fdda7-787a-4d7e-a703-9bbd812bd675 bridge supervisor0
WiFi Connect 34952175-9e72-45b0-9d41-093c096ee711 wifi --
resin-wifi-01 682b6dfc-da11-3857-8c44-4d9bd2c84070 wifi --
root@1c72c55:~# nmcli connection delete 682b6dfc-da11-3857-8c44-4d9bd2c84070
Connection 'resin-wifi-01' (682b6dfc-da11-3857-8c44-4d9bd2c84070) successfully deleted.
root@1c72c55:~# nmcli connection delete a58e405d-fdc2-3649-9339-5bbaea740c76
Connection 'resin-wifi-01' (a58e405d-fdc2-3649-9339-5bbaea740c76) successfully deleted.
(Network disconnects and the WiFi Connect captive auth enabled SSID appears, and I run through that process.)
Welcome to balenaOS
LevelUp a7785136-3dba-4697-891c-fc3d9ad2a89c wifi wlan0
If I reboot the device, the new connection is still present and the connections originally configured on the SD card come back (the resin-wifi-01 connections):
Welcome to balenaOS
supervisor0 88d91f3c-5bd6-451b-8c24-f10fdb79fc18 bridge supervisor0
resin-wifi-01 a58e405d-fdc2-3649-9339-5bbaea740c76 wifi --
This is pretty good for testing WiFi Connect, since a reboot corrects and issues I may cause.
