Release version column -- how to set
We released the action to the marketplace recently Deploy to Balena · Actions · GitHub Marketplace · GitHub.
I can discuss with the team writing a blog post about this work.
@bversluijs The action allows you to use an environment input which can be your open balena instance :slight_smile:
@20k-ultra awesome! I’ll definitely try that out in our GitHub Actions workflow, once I get that setup right :slight_smile:
But the ‘release version’ field, as asked in the topic start, is that also supported by openBalena?
Yup, openBalena will produce the release version as well just check if you have the latest version as the change was introduced within the last 6 months.
Take a look at my action testing repo to see my workflow file and the output.
If people need any features make an issue and I’ll respond!
In case it’s useful: It took me a while to figure out how to get Github Actions to ignore readme only changes (why doesn’t Github make this easier?) so that a deployment is not trigged if I change some documentation without changing the app.
Here’s my setup… Probably could be better, but it works.
on:
  push:
    paths-ignore:
      - './docs/**'
      - '**.md'
      - 'README.md'
      - '.gitpod.yml'
      - '.gitignore'
    branches:
      - master
jobs:
  balena_cloud_build:
    runs-on: ubuntu-latest
    steps:
      - name: Checkout
        uses: actions/checkout@v2
      - name: Deploy to Balena
        uses: balena-io/deploy-to-balena-action@master
        with:
          balena_token: ${{ secrets.BALENA_TOKEN }}
          fleet: ${{ secrets.BALENA_FLEET_SLUG }}
      - name: Log release ID built
        run: echo "Built release ID ${{ steps.deploy.outputs.release_id }}"
I’m sorry, I am still having issues with this.
I am using the following commands in combination with a docker-compose.yml:
balena login --token "$BALENA_TOKEN"
echo -e "type: sw.application\nversion: ${BITBUCKET_TAG}" | tee balena.yml
balena deploy MyAppName --debug
In the debug logging there is no mention of the balena.yml being parsed. I also tried .balena/balena.yml and $HOME/.balena/balena.yml.
Any suggestions here? I am not sure if the balena.yml file is not found or that my config is still wrong.
Output yaml file looks like this:
version: 0.0.7
Ah, found it!
I was using an old balena-cli version it seems.
Hi folks,
When using a docker-compose.yml, is the version in the balena.yml respected?
We currently use balena cli 21.1.9 and balena-io-examples/setup-balena-action. Should we replace it for the balena-io/deploy-to-balena-action ?
