Hello, this must be an FAQ.?. I would like to reclaim the use of the HDMI output on my devices raspberry pi, rather than display the logo?
I really need the output for diagnostics, but rather not have to wire up another tftp device or whatever …
Can this be done with boot configs, or similar?
Thank You!
Hi Rusty, you absolutely can make use of the HDMI port on the Raspberry Pi, via a container running an application! Our balenaDash project is an easy example project that will get you started: https://www.balena.io/blog/make-a-web-frame-with-raspberry-pi-in-30-minutes/
Or, if you’d like to run a full desktop OS in a container, have a look at this article: https://www.balena.io/blog/running-a-desktop-manager-with-balena/
Hope that helps!
Very cool, that is exactly what I needed!!!
