I’m starting to work on Rust using a Raspberry Pi Zero. For simple applications not using external crates builds were running fine, but on including external crates cargo segfaults in qemu. I’ve verified that this runs on the host hardware fine, it only fails in the docker run.
push run:
[Build] Step 7 : RUN cargo build
[Build] ---> Running in e106b0574d1f
[Build] Updating registry `https://github.com/rust-lang/crates.io-index`
[Info] Still working...
[Build] Downloading blinkt v0.1.2
[Build] Downloading quick-error v1.2.0
[Build] Downloading rppal v0.1.3
[Build] Downloading enum_primitive v0.1.1
[Build] Downloading num v0.1.37
[Build] Downloading libc v0.2.23
[Build] Downloading num-traits v0.1.37
[Build] Downloading num-iter v0.1.33
[Build] Downloading num-integer v0.1.34
[Build] Compiling libc v0.2.23
[Build] Compiling num-traits v0.1.37qemu: uncaught target signal 11 (Segmentation fault) - core dumped
[Build] Segmentation fault (core dumped)
[Build] Removing intermediate container e106b0574d1f
[Error] Build failed: The command '/bin/sh -c cargo build' returned a non-zero code: 139
native run:
Compiling num-integer v0.1.34
Compiling num-iter v0.1.33
Compiling num v0.1.37
Compiling quick-error v1.2.0
Compiling enum_primitive v0.1.1
Compiling rppal v0.1.3
Compiling blinkt v0.1.2
Compiling resin-rust-hello-world v0.1.0 (file:///usr/src/app)
Finished dev [unoptimized + debuginfo] target(s) in 131.35 secs
