I am trying to get an app that relies on the directory on the host: /lib/modules/4.14.39/ and the device on the host: /dev/i2c-1, which are both available on the host. I am using the latest resinOS and also attempted to use a python resin image, since the app is python-based. I am working with a RPi3.
I can see the following message and then the container goes into a restart loop:
Jul 31 04:28:47 04fd668 healthdog[762]: time="2018-07-31T04:28:47.279490698Z" level=warning
msg="Couldn't run auplink before unmount
/var/lib/docker/aufs/mnt/d7af73be3ac247993662b692d5c5ed1730e4e08286d485ce9bfdbfc702ac440e:
signal: segmentation fault (core dumped)"
31.07.18 00:37:53 (-0400) Service exited 'main
sha256:147eacd58ddc9c18994e20ef05b9f038e1ac875efb19266e7c804bc2930e1
This is what I see on the host:
root@04fd668:~# ls -la
/var/lib/docker/aufs/mnt/d7af73be3ac247993662b692d5c5ed1730e4e08286d485ce9bfdbfc702ac440e*
total 8
drwxr-xr-x 2 root root 4096 Jul 31 04:27 .
drwx------ 36 root root 4096 Jul 31 04:27 ..
/var/lib/docker/aufs/mnt/d7af73be3ac247993662b692d5c5ed1730e4e08286d485ce9bfdbfc702ac440e-init:
total 8
It seems like the host is trying to run “auplink” but it is providing a segmentation fault:
root@04fd668:~# auplink
Segmentation fault (core dumped)
I can’t seem to get around this. Any ideas?
