Raspberry Pi Zero 2s don't reconnect if the connection drops?
Hi everyone! I’ve been using some Raspberry Pi Zero 2s as IOT hosts for some simple devices. The issue I’m running into is, if a host loses its connection, that’s it. It won’t auto reconnect. I have to reboot the device, which does solve the issue. Checking the status LED when this happens, 4 blinks, network issue.
I set these devices up by first adding a debug network I use via mobile hotspot from my laptop. Then I log in via SSH through the Balena dashboard and add the final wifi credentials using this script:
#!/bin/bash
ssid=---REDACTED---
password=---REDACTED---
connections_temp=/etc/NetworkManager/system-connections/
connections_perm=/mnt/boot/system-connections/
wifi_adapter=wlan0
nmcli connection add type wifi ifname "$wifi_adapter" con-name "$ssid" ssid "$ssid"
nmcli connection modify "$ssid" wifi-sec.key-mgmt wpa-psk wifi-sec.psk "$password" wifi.hidden yes
cd $connections_temp
cp *.nmconnection $connections_perm
cd $connections_perm
chmod 600 *.nmconnection
Do I need to add some kind of parameter to my nmcli calls to tell the system to auto-reconnect?
