Raspberry Pi 5: activate both camera ports cam0 and cam1
Hi there,
I have two Raspberry Pi HQ Cameras connected to my Pi 5, but only one works…
The problem is: dtoverlay cannot be configured to stay in one line, what happens is the following:
BALENA_HOST_CONFIG_dtoverlay = imx477,cam0
leads to:
root@8716879:~# cat /mnt/boot/config.txt
extra_cmdline=cma=256M
dtparam=i2c_arm=on
dtparam=spi=on
dtparam=audio=on
avoid_warnings=1
disable_splash=1
enable_uart=0
dtoverlay=imx477
dtparam=cam0
Like this, it uses the fallback port cam0, which is fine when you have 1 camera, but you cannot open the port cam1 as for that we would need:
dtoverlay=imx477,cam1
PS: putting it in quotation marks doesnt solve the problem:
BALENA_HOST_CONFIG_dtoverlay = “imx477,cam1”
I think there is a post that explains how they did it - Problems adding dtparam and dtoverlay variables in /boot/config.txt
Cheers
