dtoverlay config converted into dtparam
I have a Raspbery Pi 5 and a Raspberry Pi Camera Module 3 that I am trying to get to work.
I have taken a look at similar projects but no solution has worked for me. I have downloaded the latest BalenaOS version 6.5.50+rev2 with supervisor version 17.0.3.
I have set the following config files. (I am using openBalena so this is all done through balena_cli btw)
ID NAME                                  VALUE                    FLEET
45 BALENA_HOST_CONFIG_arm_64bit          1                        admin/beta-ua
47 BALENA_HOST_CONFIG_arm_boost          1                        admin/beta-ua
42 BALENA_HOST_CONFIG_auto_initramfs     1                        admin/beta-ua
40 BALENA_HOST_CONFIG_camera_auto_detect 1                        admin/beta-ua
50 BALENA_HOST_CONFIG_dtoverlay          vc4-kms-v3d,uart4,imx708 admin/beta-ua
49 BALENA_HOST_CONFIG_dtparam            uart0=on                 admin/beta-ua
48 BALENA_HOST_CONFIG_enable_uart        1                        admin/beta-ua
61 BALENA_HOST_CONFIG_gpu_mem            128                      admin/beta-ua
43 BALENA_HOST_CONFIG_max_framebuffers   2                        admin/beta-ua
Yet when I check /mnt/boot/config.txt, I see the following
camera_auto_detect=1
display_auto_detect=1
auto_initramfs=1
max_framebuffers=2
disable_fw_kms_setup=1
arm_64bit=1
disable_overscan=1
arm_boost=1
enable_uart=1
dtparam=uart0=on
gpu_mem=128
disable_splash=1
avoid_warnings=1
dtoverlay=vc4-kms-v3d
dtparam=uart4
dtparam=imx708
I do not understand why uart4 and imx708 are set as dtparams instead of dtoverlays like I have specified. I used the following comma seperated list s per the documentation.
balena env set BALENA_HOST_CONFIG_dtoverlay "vc4-kms-v3d","uart4","imx708" --fleet beta-ua
In addition the dtbo can be seen in /mnt/boot/overlays/imx708.dtbo
I do not know if that is my issue. But whenever I get into my container and check for cameras, I get an empty list.
python3 -c “from picamera2 import Picamera2; print(Picamera2.global_camera_info())”
[0:13:39.440025659] [40]  INFO Camera camera_manager.cpp:330 libcamera v0.5.2+99-bfd68f78
My container is privlidged, I have the devices explicitly added, and I do have the labels in place
labels:
      io.balena.features.supervisor-api: 1
      io.balena.features.kernel-modules: 1
      io.balena.features.firmware: 1
      io.balena.features.dbus: 1
      io.balena.features.sysfs: 1
      io.balena.features.udev: 1
So just in case anyone else is having the same issue, you need to wrap it around single quotes.
So instead of this
It needs to be this
balena env set BALENA_HOST_CONFIG_dtoverlay '"vc4-kms-v3d","uart4","imx708"' --fleet beta-ua
When not wrapped around single quotes, for some weird reason it does not throw any errors or warnings but instead applies everything except the first item as a dtparam. (I guess in hindsight, it thinks everything following the first item is a param of the first item)
