I was deploying the MING stack on my Raspberry Pi 4 (64-bit) and the initial deployment was successful. I used Balena Etcher to flash my SD card. After that, I could see the device online and saw it updating the device over OTA. It took around 30 minutes to download updates and components like Grafana, MQTT, InfluxDB, and Node-RED. Along with those, I noticed another component, Wifi-Connect. When it completed, it started to install, and immediately my device lost the Wi-Fi connection.
I rebooted the device and found it connected to Wi-Fi, displaying “online (VPN only)” in the Balena Cloud dashboard. A few seconds later, my device went offline again.
Hello @Thaha first of all welcome to the balena community!
Today I had the same experience. Disabling the WiFi-Connect container it works and I’m going to explore why is this not running. I will keep you posted!
Hello @Thaha if you don’t need wifi-connect my recommendation is to clone the repository and comment with # the lines related to the wifi-connect service on the docker-compose.yml file.
Then run balena push <your-fleet> and that might work!
I still didn’t find time to research why is this not working! Apologizes!
Thank you @mpous … I pushed the fleet without wifi-connect and now the device is online. However, I have encountered another issue. In the dashboard, it shows that Node-RED, Grafana, MQTT, and InfluxDB are online, but when I tried to open their ports, none of them are accessible. I also tried with the public URL, but I am getting the error: tunneling socket could not be established: 500. One possible reason is that nothing is listening on port 80 on the device. I can run the Node-RED instance manually by opening the terminal on the target device using command node-red
