I followed this tutorial https://www.balena.io/blog/deploy-a-digital-signage-application-with-screenly-and-resin/
I used a development image for balena.
Now i want to have one for production. When i tried to push it via git bash i get the following error:
“fatal: remote balena already exists.”
How do i push the code to the second app i created?
Hi @gh_shukhratk and welcome to the forums!
You have a couple of options:
- You can remove the remote for your first app by running
git remote remove balena, after which you can try adding the remote for your second application again (with the command from the top right of the dashboard), and then push in the same way.
- You can add the second app alongside the first, so instead of running
git remote add balena <username>@... you can change this to something like git remote add balenaprod <username>@... and then you can push with git push balenaprod master.
I hope this helps and good luck!
Hi @chrisys
Thanks for the welcoming and your quick response.
I will give that a try and let u know.
