Our supported way of sending AT commands is through Modem Manager, you can do that by using: mmcli -m 0 --command="ATI"
For you to be able to use microcom while the modem is being managed by modem manager, the modem would need to support multiple AT ports. We would still recommend you go through modem manager, since it’s managing the connection.
Thanks for the heads up, that explains a lot. However, next step is to get GPS data through Modem Manager. The following command is necessary in order to enable GNSS for Quectel; mmcli -m 0 --command="AT+QGPS=1"
NMEA traces can be seen in /dev/ttyUSB1 accordingly (without fix because antenna is not connected). How would one get location data through Modem Manager in this case?
