Possible to use Python pyFirmata to set next wake-up time of CML3. I’d like to switch-off CML3 module by module itself, but before I need to set/confirm next wake-up value on ARTIK co-processor.
thx in advance
thx in advance
Hi @freddy34,
This is coming soon to the Firmata firmware; we’re planning to get an initial “serial command to set a sleep” (CM3 -> Coprocessor) interval example into the docs asap followed by implementing this upstream into the Firmata firmware shortly afterwards.
This will likely be implemented as a custom SYSEX command and I’ll let you know as soon as it’s been pushed to the Firmata firmware.
Alex
Hi Alex, some news about new Firmata FW?
et
Hi @freddy34, apologies for the delay with this, I think this being marked as a solution meant that I didn’t see your prompt! You can find the updated firmata firmware here (https://github.com/balena-io/balena-fin-coprocessor-firmata) and a test program which will load and run the firmata firmware (https://github.com/balena-io-playground/balena-fin-firmata-flash/tree/v1.1-beta2).
