Pushing code to fleet of devices
Actually I have 3 Raspberry Pi’s in a single application. I need the same application code running in all the three. Clearly, what I need is that by pushing the code only once in the single application can we update in all devices. Help me out urgency.
Hi @geethika , can you explain what the problem is? By default all devices that are in an application will run the same code and all devices should update when you push new code. If this is not the case can you show us the logs that the faulty devices are producing on their dashboard?
@balena team
Thank you for the support there are no faulty devices the thing is does each device in the application runs the same code deployed in that application.
@geethika yes all devices in a application will run the same code.
