FROM tobi312/rpi-nginx
RUN apt-get update && \
apt-get install telnet nano iputils-ping less kmod nano net-tools ifupdown i2c-tools usbutils wget curl gvfs ipheth-utils gvfs-backends gvfs-bin gvfs-fuse ifuse libimobiledevice-utils usbmuxd dnsmasq && \
apt-get clean && \
rm -rf /var/lib/apt/lists/*
COPY start.sh start.sh
COPY nginx.conf /etc/nginx/nginx.conf
# This will copy all files in our root to the working directory in the container
COPY . /usr/share/nginx/html/
#COPY iphoneconnect /lib/udev/iphoneconnect
#RUN chmod 755 /lib/udev/iphoneconnect
#COPY 90-iphone-tether.rules /lib/udev/rules.d/90-iphone-tether.rules
COPY 39-usbmuxd.rules /lib/udev/rules.d/39-usbmuxd.rules
COPY dnsmasq.conf /etc/dnsmasq.conf
# Enable systemd init system in container
ENV INITSYSTEM on
CMD ["bash", "start.sh"]
and node/dockerfile.template
apt-get install telnet nano iputils-ping less kmod nano net-tools ifupdown i2c-tools libcairo2-dev libjpeg-dev libpango1.0-dev libgif-dev build-essential libssl-dev g++ samba avahi-daemon avahi-discover wget curl cups printer-driver-gutenprint usbutils gphoto2=2.5.11-1 imagemagick && \
apt-get clean && \
# node install
RUN curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
RUN apt-get install -y nodejs
RUN useradd pi && \
echo "user ALL=(root) NOPASSWD:ALL" > /etc/sudoers.d/user && \
chmod 0440 /etc/sudoers.d/user && \
echo "pi:raspberry"|chpasswd && \
usermod -a -G lpadmin pi
# RUN wget https://raw.githubusercontent.com/gonzalo/gphoto2-updater/master/gphoto2-updater.sh && chmod +x gphoto2-updater.sh && sudo ./gphoto2-updater.sh --development
# Defines our working directory in container
WORKDIR /usr/src/app
# Copies the package.json first for better cache on later pushes
COPY ./package.json package.json
COPY ./cupsd.conf /etc/cups/cupsd.conf
COPY ./printers.conf /etc/cups/printers.conf
# This install npm dependencies on the resin.io build server,
# making sure to clean up the artifacts it creates in order to reduce the image size.
RUN npm install pm2 -g --no-optional
RUN JOBS=MAX npm install --production --unsafe-perm && rm -rf /tmp/*
COPY . ./
ENV INITSYSTEM on
Please note that both containers are failing so it must be related to the tobi312/rpi-nginx image specifically.
I also posted the issue on github:
and find a similar closed issue that seems related:
I think the maintainer of tobi312/rpi-nginx on Dockerhub has fixed the issue. Before their fix, I was running some tests with balena push <ipAddress> on a Raspberry Pi with the tobi312/rpi-nginx image, and I was getting errors like "/bin/sleep: cannot execute binary file" – as if /bin/sleep had been compiled for another architecture than ARM. After their fix, that problem went away and I was also able to push a trivial Dockerfile to the balenaCloud builders with success:
CMD while : ; do echo tobi312/rpi-nginx; sleep 5; done
