Problem building - read ECONNRESET
Update from the status page:
Balena.io Status - 32bit Arm builds on `arm03` unavailable
We have restored our build pipeline, but with all builds going through our emulation pipeline. We’re working on fixing a strange interaction of Go with libc that sometimes leads to a segfault in our native ARM builders. We expect to have new binaries deployed in the next 24 hours.
Thanks, I will try again ASAP
  1. The build gets stuck installing npm libraries, and suddenly breaks. (This only happens when using “balena-emulated”)
@BryanMontes, this could be an incompatibility with QEMU: i.e., your builds fail with emulation and require native ARM hardware.
  1. The build crashes when trying to get libraries from a repo and throws An error occurred: read ECONNRESET (this happens when pushing to master or balena-nocache)
The ECONNRESET error was associated with a native ARM server (arm03) that has now been temporarily taken out for investigation and fix (to be restored within 24h according to the most recent status update). You shouldn’t be getting ECONNRESET errors with QEMU emulation on x86 servers, but the builds can be much slower – or fail altogether in case of QEMU incompatibility.
In both cases, a temporary alternative may be to use your own hardware to run the builds (instead of the balenaCloud builders), whether a local balenaFin / Raspberry Pi native ARM device running a development image of balenaOS, or your x86 laptop or desktop computer running Docker. In these cases, the “balena build + balena deploy” commands would be used instead of the “balena push” or “git push” commands. The “balena build” command automatically runs QEMU on Docker in order emulate ARM on x86 processors. In the case of a native ARM device running a development image of balenaOS, specify the IP address and port number of the docker daemon on the balenaOS device (the port number is 2375), for example:
balena build ... -h 192.168.2.15 -p 2375
Check the documentation for “balena build” and “balena deploy” on these pages:
To be clear, the above is only useful if you have come across QEMU incompatibility, or if you think that your own x86 hardware would be faster than the balenaCloud x86 servers.
I’m still getting the issue with arm3 builder but I managed to compile with arm1 (it randomly selects arm 1 when compiling using git push balena master)
Hi there! Those issues should have been resolved. Please feel free to reach out in case you encounter any issues. Best regards
For visibility, I’ve been hitting this issue more recently (sept 15, 2025) and created a topic here: Balena push not working
