I’m doing a balena push from the CLI which was working for me last week, but this week I’ve been hitting this error:
| Uploading source package to https://builder.balena-cloud.com[debug] received HTTP 200 OK
[debug] handling message: {“type”:“metadata”,“resource”:“buildLogId”,“value”:“3666978”}
ECONNRESET: The server aborted pending request
ReadError: The server aborted pending request
at IncomingMessage. (/usr/local/lib/balena-cli/node_modules/got/dist/source/core/index.js:809:31)
at Object.onceWrapper (node:events:632:28)
at IncomingMessage.emit (node:events:530:35)
at origin.emit (/usr/local/lib/balena-cli/node_modules/@szmarczak/http-timer/dist/source/index.js:43:20)
at IncomingMessage._destroy (node:_http_incoming:221:10)
at _destroy (node:internal/streams/destroy:122:10)
at IncomingMessage.destroy (node:internal/streams/destroy:84:5)
at TLSSocket.socketCloseListener (node:_http_client:478:11)
at TLSSocket.emit (node:events:530:35)
at node:net:346:12
at TCP.done (node:_tls_wrap:650:7)
We opened Incident: Builder partially degraded service. It’s current status is Monitoring: A fix has been implemented and we are monitoring the results. So it is not fully resolved. But it would be helpful to know - are you still experiencing the issue?
Hi @erlam, thank you for the report. The incident above is being actively monitored and worked on. If this is indeed the the cause in your case, then the best thing to do is monitor the incident. Note that you can subscribe to email notifications there.
