Prevent SD-Card Corruption
I’ve followed your links and the links in the linked articles, that’s really interesting.
If I had to sum it up : use larger cards than u need, and high quality ones so the flash controller doesn’t use always the same block. No need to go for SLC (4 Go for 850€), when larger cards may do the trick.
