Ok, tried the new openBalena and the latest cli. But finally failed!
Any idea?
Any idea?
Hi Wester, I can see balenaOS is packaged with supervisor v11.12.4. There is a bug in the local mode preload flow with versions prior to v.12.0.6.
Please check my comment above: Preloaded Image Doesn't Start
11.12.4
Thank you. I am pretty sure you are hitting the bug with the local mode preload, which was fixed in v12.0.6. I am just sourcing internally how best to proceed…
Thanks for your quick reply!
Any idea on the new openBalena and balena-cli issue? OpenBalena: Cannot create Application!
I can confirm this issue will be resolved in supervisor v12.0.6 when it’s released.
Is there anyway to upgrade the supervisor to the latest manually on balenaOS image?
Hey Wester
I think it’s best if you wait for the official release to happen. Since all the components in question are opensource, you could try and build something yourself but that’s a lot more work.
@anujdeshpande @ab77 Any idea when the balenaOS images use v12.0.6?
2.58.3+rev4 still uses v11.14.0…
hey Shane, the supervisor v12.1.1 was merged into balenaOS 2.61.0 https://github.com/balena-os/meta-balena/blob/master/CHANGELOG.md#v2610 . So you should see that version rolling out on the RPi family in the next week or so.
Hi, @shaunmulligan
Any update here?
This version of the OS isn’t available on production yet, but you can monitor progress here: https://balena-io.github.io/balenaosversions/
Just wanted to check when 2.61.0 will be ready for the RPi production image?
Hey.
We don’t normally provide any exact ETAs. However, we’re always working on bringing the latest OS versions to as many devices as possible. I’d suggest to keep an eye on our page.
Cheers!
