Greetings,
I am attempting to establish a ppp connection in the base resin OS. My company has forked the resin OS repo and we have added some cellular modem power management layers that are specific to our usage.
We are using a NimbeLink (Cinterion/Gemalto) Skywire LTE CAT1 modem. The modem plugs into a custom hardware board (using RaspberryPi Compute Module 3) via a Zigbee-style socket running resin OS. I have spent lots of time trying to establish connections using NetworkManager/ModemManager, however, success rate is about 25% at best. The vendor has advised not to use ModemManger as their firmware is “not 100% compatible”. They suggest using pon commands directly and a dialer script. (This modem is booted and initialized using a handful of GPIO pins; no issue here.)
The dialer script via pon works great on a bare-bones Raspian build running on the same hardware. Using picocom works as expected to interact with the modem as well as establishing the PPP connection.
On ResinOS it’s a different story. NetworkManager/ModemManger continually disconnects and reconnects the modem causing the usb device to come and go (modem ultimately will register as /dev/serial0 --> /dev/ttyAMA0). Manually stopping these 2 services by-hand in Resin OS prevents the disconnect/reconnect dance as noted by the modem vendor. However, pon always fails to connect. When using picocom to interact with the modem, issued commands hang or partially complete.
Ideally, we want to use ModemManager, but with this specific modem, it’s not looking possible. We want to establish the connection at the OS-level, not from within a container. Our container application will simply pick up and use the connection established at the OS-level. Previously, we did have some luck managing power state for the modem when using a container and we had to set ‘UDEV off’ in the Dockerfile (env var). Success rate still very low.
I am looking for any guidance on making successful ppp/pon connections in the base Resin OS level - not via a container. I have full access to tweaking the Yocto builds, so that is not an issue for testing.
(NOTE: Resin Agent is disabled and we have injected our own Agent via the Yocto build. Running 2.13.0-rev1 in disconnected state. This is informational and has nothing to do with the above.)
Please let me know what other information I can provide.
Help is greatly appreciated.
Thank you.
