I have been trying to get the rpi camera to work but it seems there’s something wrong with the io.balena.features.kernel-modules label. These are my Dockerfile and docker-compose file:
docker-compose.yml
version: '2.1'
services:
picture:
build: .
restart: always
privileged: true
labels:
io.balena.features.kernel-modules: '1'
io.balena.features.dbus: '1'
Dockerfile
FROM balenalib/raspberry-pi-alpine-python:3.7-3.8
RUN pip install -U pip \
&& READTHEDOCS=True pip install --no-cache-dir picamera
WORKDIR /src
COPY . .
CMD modprobe v4l2_common && python test.py
My test.py file just imports the picamera module.
This will always result in the following error:
19.03.19 23:11:12 (+0100) test-image Traceback (most recent call last):
19.03.19 23:11:12 (+0100) test-image File "sample.py", line 2, in <module>
19.03.19 23:11:12 (+0100) test-image import picamera
19.03.19 23:11:12 (+0100) test-image File "/usr/local/lib/python2.7/site-packages/picamera/__init__.py", line 72, in <module>
19.03.19 23:11:12 (+0100) test-image from picamera.exc import (
19.03.19 23:11:12 (+0100) test-image File "/usr/local/lib/python2.7/site-packages/picamera/exc.py", line 41, in <module>
19.03.19 23:11:12 (+0100) test-image import picamera.mmal as mmal
19.03.19 23:11:12 (+0100) test-image File "/usr/local/lib/python2.7/site-packages/picamera/mmal.py", line 47, in <module>
19.03.19 23:11:12 (+0100) test-image from .bcm_host import VCOS_UNSIGNED
19.03.19 23:11:12 (+0100) test-image File "/usr/local/lib/python2.7/site-packages/picamera/bcm_host.py", line 47, in <module>
19.03.19 23:11:12 (+0100) test-image _lib = ct.CDLL('libbcm_host.so')
19.03.19 23:11:12 (+0100) test-image File "/usr/local/lib/python2.7/ctypes/__init__.py", line 366, in __init__
19.03.19 23:11:12 (+0100) test-image self._handle = _dlopen(self._name, mode)
19.03.19 23:11:12 (+0100) test-image OSError: libbcm_host.so: cannot open shared object file: No such file or directory
I have tried the example provided on https://github.com/balena-io-projects/balena-rpi-python-picamera and I get the exact same result.
Can anyone look into this? I’m trying this on both a RPi Zero W and a RPi3-B
Thank you.
Can’t install
