Hello gurus,
I’m attempting to run raspistill on a Pi Zero Wireless. I’ve had success without balena.io installed, however it’s far more useful to have it dockerized and here.
I’m having pretty good luck on setup thus far. I have two services running with volumes created and mounted/shared (cool), one service that doesn’t do much yet (“motion-capturer”) and one that is managing raspistill processes via node.
Challenge: Separate from the Nodejs thing (which is working great on its own), if I login to the raspistill-manager host and run raspistill, I get a nice menu of things I can do. It’s there! However, if I run a capture command e.g. raspistill -o cam.jpg, I get this error:
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
I’m not quite sure where to continue with this one. For fleet config vars, I have:
RESIN_HOST_CONFIG_gpu_mem = 128
RESIN_HOST_CONFIG_start_x = 1
I’m not sure if this is being pulled into the single device yet or not.
docker-compose.yml:
version: '2'
volumes:
# This RAM drive is for raspicam to place a constant stream of images while not
# burning out MicroSD card, pending motion detection and move to image-ready.
image-temp:
driver_opts:
type: tmpfs
device: tmpfs
# 128MB (in bytes)
# Images are stored here when motion is detected, ready for upload when possible.
image-ready:
services:
raspistill-manager:
build: ./raspistill-manager
# doesn't seem to make a difference beyond devices, should* remove?:
privileged: true
volumes:
- 'image-temp:/image-temp'
devices:
- /dev/dri:/dev/dri #optional temporary for reference
# next one required by raspistill:
- /dev/vchiq:/dev/vchiq #optional KEEP THIS ONE OTHERWISE NO RUN RASPISTILL
- /dev/video10:/dev/video10 #optional temporary for reference
- /dev/video11:/dev/video11 #optional temporary for reference
- /dev/video12:/dev/video12 #optional temporary for reference
motion-capturer:
build: ./motion-capturer
volumes:
- 'image-ready:/image-ready'
raspistill-manager Dockerfile.template:
# First Stage: Compile TypeScript #
# Thanks: https://stackoverflow.com/questions/60916271/how-do-i-run-typescript-tsc-before-copy-in-dockerfile-template/60917273#60917273
FROM balenalib/%%BALENA_MACHINE_NAME%%-node AS build
# Install needed packages to build raspicam Node dependencies.
RUN install_packages libraspberrypi-bin
WORKDIR /usr/src/app
# Install the Javascript dependencies, including all devDependencies.
COPY package.json .
RUN npm i
# Copy the rest of the application in and build it.
COPY . ./
# RUN npm build
RUN ./node_modules/typescript/bin/tsc -p ./tsconfig.json
# Clean up node_modules to not include dev dependencies.
RUN rm -rf ./node_modules
RUN JOBS=MAX npm i --production
# Second Stage: Prepare Dist App #
# Defines our working directory in container
# Install packages
# Copy needed files in root to the working directory in the container
COPY --from=build /usr/src/app/dist dist
COPY --from=build /usr/src/app/node_modules dist/node_modules
COPY package.json package.json
# server.js will run when container starts up on the device
CMD ["npm", "run", "serve"]
Any thoughts on how I should proceed? Thanks for taking a look in advance!
EDIT: Do I need to pass these in via environment yml option by chance?
EDIT: I’m catching up on this related looking post.
