I’m trying to update Balena OS on a rpi3 device and the update freezes at 50% and then fails after a long delay.
I can’t figure out why it’s not working. I tried rebooting the device, purging data, moving the device to an empty app with no services… nothing fixed the issue. I looked at the logs but I don’t see any obvious causes.
root@cd44093:~# journalctl -f
-- Logs begin at Sun 2020-08-16 10:31:39 UTC. --
Apr 27 20:11:20 cd44093 redsocks[1388]: 1619554280.137823 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:57062->52.55.60.119:443]: accepted
Apr 27 20:11:21 cd44093 redsocks[1388]: 1619554281.357814 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:55698->107.20.209.223:443]: connection closed
Apr 27 20:11:21 cd44093 redsocks[1388]: 1619554281.627490 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:59492->18.209.132.178:443]: connection closed
Apr 27 20:11:22 cd44093 redsocks[1388]: 1619554282.013891 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:57062->52.55.60.119:443]: connection closed
Apr 27 20:11:25 cd44093 chronyd[1238]: 2021-04-27T20:11:25Z Selected source 94.130.49.186
Apr 27 20:11:30 cd44093 redsocks[1388]: 1619554290.145803 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:55710->107.20.209.223:443]: accepted
Apr 27 20:11:32 cd44093 sshd[2138]: error: Could not load host key: /etc/ssh/hostkeys/ssh_host_dsa_key
Apr 27 20:11:32 cd44093 redsocks[1388]: 1619554292.938656 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:55710->107.20.209.223:443]: connection closed
Apr 27 20:11:35 cd44093 sshd[2138]: Accepted publickey for root from 10.253.1.204 port 64273 ssh2: RSA SHA256:eOTg1eCVsaImU+sXoErVsOh5d0CQJQ9sGot46OWtm+0
Apr 27 20:11:40 cd44093 redsocks[1388]: 1619554300.990649 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:59504->18.209.132.178:443]: accepted
Apr 27 20:11:44 cd44093 redsocks[1388]: 1619554304.212792 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:59504->18.209.132.178:443]: connection closed
Apr 27 20:12:20 cd44093 redsocks[1388]: 1619554340.033887 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:59460->18.209.132.178:443]: connection closed
Apr 27 20:13:56 cd44093 balenad[1338]: time="2021-04-27T20:13:56.124084458Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/ed8c749d73fbb0e5b60161b3c79950a2c4ace661ea43a8438c26174bc6cf40cd.sock debug=false pid=2287
Apr 27 20:13:58 cd44093 balenad[1338]: time="2021-04-27T20:13:58.211807623Z" level=info msg="shim reaped" id=f222c8e584a744acd0c2c2b59f655cec6d191e3603b2190ea6dfb2c28f296ed1
Apr 27 20:13:58 cd44093 balenad[1338]: time="2021-04-27T20:13:58.222371637Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:15:56 cd44093 3cdca6b90c30[1338]: [api] GET /v1/healthy 200 - 9.359 ms
Apr 27 20:15:56 cd44093 resin-supervisor[1727]: [api] GET /v1/healthy 200 - 9.359 ms
Apr 27 20:16:59 cd44093 balenad[1338]: time="2021-04-27T20:16:59.655238155Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/2aff3d274833f1a0498221c4b3dbf304401c55e0cf4baa01fa7acd34dfc4689d.sock debug=false pid=2538
Apr 27 20:17:01 cd44093 balenad[1338]: time="2021-04-27T20:17:01.626084572Z" level=info msg="shim reaped" id=6aef6bf788d26c0f4022708f2bd75252b623969a876a2c52f088fe0ad57826e6
Apr 27 20:17:01 cd44093 balenad[1338]: time="2021-04-27T20:17:01.631964336Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:20:03 cd44093 balenad[1338]: time="2021-04-27T20:20:03.077600534Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/f8ef978c3e06ac3c741431bc94240cda9836119ed02d5d53a2b65f526807794c.sock debug=false pid=2695
Apr 27 20:20:05 cd44093 balenad[1338]: time="2021-04-27T20:20:05.131466149Z" level=info msg="shim reaped" id=be19050cf87a817aedd02bf4cb729e626679bed5bc1040356370cafb92303a7d
Apr 27 20:20:05 cd44093 balenad[1338]: time="2021-04-27T20:20:05.139406737Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:20:57 cd44093 resin-supervisor[1727]: [api] GET /v1/healthy 200 - 14.866 ms
Apr 27 20:20:57 cd44093 3cdca6b90c30[1338]: [api] GET /v1/healthy 200 - 14.866 ms
Apr 27 20:20:59 cd44093 3cdca6b90c30[1338]: [debug] Attempting container log timestamp flush...
Apr 27 20:20:59 cd44093 resin-supervisor[1727]: [debug] Attempting container log timestamp flush...
Apr 27 20:20:59 cd44093 resin-supervisor[1727]: [debug] Container log timestamp flush complete
Apr 27 20:20:59 cd44093 3cdca6b90c30[1338]: [debug] Container log timestamp flush complete
Apr 27 20:23:06 cd44093 balenad[1338]: time="2021-04-27T20:23:06.472627780Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/1a4e0f022aab72567ed35f7cbebae1620c89e2244d25146f1b02fb7fad8d077c.sock debug=false pid=2945
Apr 27 20:23:08 cd44093 balenad[1338]: time="2021-04-27T20:23:08.511883047Z" level=info msg="shim reaped" id=812fcb885e0d487e0936b9738ff64041da65ffab9519791452601bc4a9aa1bd5
Apr 27 20:23:08 cd44093 balenad[1338]: time="2021-04-27T20:23:08.520703162Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:25:33 cd44093 systemd-tmpfiles[3059]: [/etc/tmpfiles.d/openvpn.conf:1] Line references path below legacy directory /var/run/, updating /var/run/openvpn → /run/openvpn; please update the tmpfiles.d/ drop-in file accordingly.
Apr 27 20:25:34 cd44093 sh[3058]: Getting image name and tag...
Apr 27 20:25:34 cd44093 redsocks[1388]: 1619555134.260249 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:57086->52.55.60.119:443]: accepted
Apr 27 20:25:34 cd44093 sshd[3079]: error: Could not load host key: /etc/ssh/hostkeys/ssh_host_dsa_key
Apr 27 20:25:36 cd44093 sh[3058]: Supervisor configuration found from API.
Apr 27 20:25:36 cd44093 sh[3058]: Getting image id...
Apr 27 20:25:36 cd44093 sh[3058]: Supervisor registry2.balena-cloud.com/v2/e5a9b95f08373b03979ee007184e4753:latest already downloaded.
Apr 27 20:25:36 cd44093 redsocks[1388]: 1619555136.962819 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:57086->52.55.60.119:443]: connection closed
Apr 27 20:25:40 cd44093 sshd[3079]: Accepted publickey for root from 52.4.252.97 port 53354 ssh2: RSA SHA256:gMJ9LgzkTHsYjz4l3biYiuugYoYyRnQBGkMnNJhRqUQ
Apr 27 20:25:48 cd44093 redsocks[1388]: 1619555148.327485 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:59524->18.209.132.178:443]: accepted
Apr 27 20:25:51 cd44093 redsocks[1388]: 1619555151.090551 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:59524->18.209.132.178:443]: connection closed
Apr 27 20:25:51 cd44093 redsocks[1388]: 1619555151.754036 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:57094->52.55.60.119:443]: accepted
Apr 27 20:25:54 cd44093 redsocks[1388]: 1619555154.188282 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:55742->107.20.209.223:443]: accepted
Apr 27 20:25:54 cd44093 redsocks[1388]: 1619555154.355799 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:57094->52.55.60.119:443]: connection closed
Apr 27 20:25:57 cd44093 redsocks[1388]: 1619555157.088365 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:55742->107.20.209.223:443]: connection closed
Apr 27 20:25:57 cd44093 redsocks[1388]: 1619555157.323179 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:59536->18.209.132.178:443]: accepted
Apr 27 20:25:58 cd44093 3cdca6b90c30[1338]: [api] GET /v1/healthy 200 - 10.593 ms
Apr 27 20:25:58 cd44093 resin-supervisor[1727]: [api] GET /v1/healthy 200 - 10.593 ms
Apr 27 20:26:00 cd44093 redsocks[1388]: 1619555160.616284 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:59536->18.209.132.178:443]: connection closed
Apr 27 20:26:00 cd44093 redsocks[1388]: 1619555160.817695 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:57108->52.55.60.119:443]: accepted
Apr 27 20:26:03 cd44093 redsocks[1388]: 1619555163.463608 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:55862->52.205.74.65:443]: accepted
Apr 27 20:26:03 cd44093 redsocks[1388]: 1619555163.653808 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:57108->52.55.60.119:443]: connection closed
Apr 27 20:26:05 cd44093 redsocks[1388]: 1619555165.925574 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:55760->107.20.209.223:443]: accepted
Apr 27 20:26:06 cd44093 redsocks[1388]: 1619555166.379945 err redsocks.c:474 redsplice_write_cb(...) [10.128.34.172:55862->52.205.74.65:443]: shutdown(client, SHUT_WR): Transport endpoint is not connected
Apr 27 20:26:06 cd44093 redsocks[1388]: 1619555166.380102 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:55862->52.205.74.65:443]: connection closed
Apr 27 20:26:09 cd44093 redsocks[1388]: 1619555169.056284 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:55760->107.20.209.223:443]: connection closed
Apr 27 20:26:09 cd44093 redsocks[1388]: 1619555169.328137 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:59554->18.209.132.178:443]: accepted
Apr 27 20:26:09 cd44093 balenad[1338]: time="2021-04-27T20:26:09.990371592Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/20c62bbeae4c3142921e7bf13fec77e43091d0fc4b99e182dea1481f1674f5d8.sock debug=false pid=3391
Apr 27 20:26:12 cd44093 redsocks[1388]: 1619555172.066227 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:59554->18.209.132.178:443]: connection closed
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.096405767Z" level=info msg="Starting up"
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.105274007Z" level=info msg="libcontainerd: started new balena-engine-containerd process" pid=3498
Apr 27 20:26:12 cd44093 balenad[1338]: time="2021-04-27T20:26:12.192518393Z" level=info msg="shim reaped" id=9f0a10618ba159b4f86272776698b90bb1b9ab11f99abd613a43aa44e6c058cc
Apr 27 20:26:12 cd44093 balenad[1338]: time="2021-04-27T20:26:12.199439975Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.255169248Z" level=info msg="starting containerd" revision= version=1.2.0+unknown
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.256966427Z" level=info msg="loading plugin \"io.containerd.content.v1.content\"..." type=io.containerd.content.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.258161369Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.aufs\"..." type=io.containerd.snapshotter.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.266577059Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.native\"..." type=io.containerd.snapshotter.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.267354556Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.overlayfs\"..." type=io.containerd.snapshotter.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.268319499Z" level=info msg="loading plugin \"io.containerd.metadata.v1.bolt\"..." type=io.containerd.metadata.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.268484967Z" level=info msg="metadata content store policy set" policy=shared
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.272921092Z" level=info msg="loading plugin \"io.containerd.differ.v1.walking\"..." type=io.containerd.differ.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.273092914Z" level=info msg="loading plugin \"io.containerd.gc.v1.scheduler\"..." type=io.containerd.gc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.273294268Z" level=info msg="loading plugin \"io.containerd.service.v1.containers-service\"..." type=io.containerd.service.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.273449007Z" level=info msg="loading plugin \"io.containerd.service.v1.content-service\"..." type=io.containerd.service.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.273564319Z" level=info msg="loading plugin \"io.containerd.service.v1.diff-service\"..." type=io.containerd.service.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.273660047Z" level=info msg="loading plugin \"io.containerd.service.v1.images-service\"..." type=io.containerd.service.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.273752130Z" level=info msg="loading plugin \"io.containerd.service.v1.leases-service\"..." type=io.containerd.service.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.273840671Z" level=info msg="loading plugin \"io.containerd.service.v1.namespaces-service\"..." type=io.containerd.service.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.273928015Z" level=info msg="loading plugin \"io.containerd.service.v1.snapshots-service\"..." type=io.containerd.service.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.274013275Z" level=info msg="loading plugin \"io.containerd.runtime.v1.linux\"..." type=io.containerd.runtime.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.274597803Z" level=info msg="loading plugin \"io.containerd.runtime.v2.task\"..." type=io.containerd.runtime.v2
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.275018270Z" level=info msg="loading plugin \"io.containerd.monitor.v1.cgroups\"..." type=io.containerd.monitor.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.278042996Z" level=info msg="loading plugin \"io.containerd.service.v1.tasks-service\"..." type=io.containerd.service.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.278278828Z" level=info msg="loading plugin \"io.containerd.internal.v1.restart\"..." type=io.containerd.internal.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.278489244Z" level=info msg="loading plugin \"io.containerd.grpc.v1.containers\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.278580701Z" level=info msg="loading plugin \"io.containerd.grpc.v1.content\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.278666326Z" level=info msg="loading plugin \"io.containerd.grpc.v1.diff\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.278751430Z" level=info msg="loading plugin \"io.containerd.grpc.v1.events\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.278841377Z" level=info msg="loading plugin \"io.containerd.grpc.v1.healthcheck\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.278931221Z" level=info msg="loading plugin \"io.containerd.grpc.v1.images\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.279018616Z" level=info msg="loading plugin \"io.containerd.grpc.v1.leases\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.279103668Z" level=info msg="loading plugin \"io.containerd.grpc.v1.namespaces\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.279185542Z" level=info msg="loading plugin \"io.containerd.internal.v1.opt\"..." type=io.containerd.internal.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.279320073Z" level=warning msg="failed to load plugin io.containerd.internal.v1.opt" error="mkdir /opt: read-only file system"
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.279395281Z" level=info msg="loading plugin \"io.containerd.grpc.v1.snapshots\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.279492416Z" level=info msg="loading plugin \"io.containerd.grpc.v1.tasks\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.279581999Z" level=info msg="loading plugin \"io.containerd.grpc.v1.version\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.279663665Z" level=info msg="loading plugin \"io.containerd.grpc.v1.introspection\"..." type=io.containerd.grpc.v1
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.280524547Z" level=info msg=serving... address=/var/run/balena-host/containerd/balena-engine-containerd-debug.sock
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.280813868Z" level=info msg=serving... address=/var/run/balena-host/containerd/balena-engine-containerd.sock.ttrpc
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.281035690Z" level=info msg=serving... address=/var/run/balena-host/containerd/balena-engine-containerd.sock
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.281113242Z" level=info msg="containerd successfully booted in 0.046171s"
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.319287023Z" level=warning msg="[graphdriver] WARNING: the aufs storage-driver is deprecated, and will be removed in a future release"
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.333139406Z" level=warning msg="[graphdriver] WARNING: the aufs storage-driver is deprecated, and will be removed in a future release"
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.538562150Z" level=warning msg="Your kernel does not support cgroup rt period"
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.538776524Z" level=warning msg="Your kernel does not support cgroup rt runtime"
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.540227767Z" level=info msg="Loading containers: start."
Apr 27 20:26:12 cd44093 balenad[3484]: time="2021-04-27T20:26:12.894528830Z" level=info msg="Loading containers: done."
Apr 27 20:26:13 cd44093 balenad[3484]: time="2021-04-27T20:26:13.175734034Z" level=info msg="Docker daemon" commit=074a481789174b4b6fd2d706086e8ffceb72e924 graphdriver(s)=aufs version=19.03.13-dev
Apr 27 20:26:13 cd44093 balenad[3484]: time="2021-04-27T20:26:13.178199387Z" level=info msg="Daemon has completed initialization"
Apr 27 20:26:13 cd44093 balenad[3484]: time="2021-04-27T20:26:13.228562330Z" level=info msg="API listen on /var/run/balena-host.sock"
Apr 27 20:26:13 cd44093 redsocks[1388]: 1619555173.514795 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:51066->3.216.122.111:443]: accepted
Apr 27 20:26:17 cd44093 redsocks[1388]: 1619555177.022799 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:59562->18.209.132.178:443]: accepted
Apr 27 20:26:17 cd44093 redsocks[1388]: 1619555177.293647 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:51066->3.216.122.111:443]: connection closed
Apr 27 20:26:20 cd44093 redsocks[1388]: 1619555180.026138 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:51074->3.216.122.111:443]: accepted
Apr 27 20:26:20 cd44093 redsocks[1388]: 1619555180.241879 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:59562->18.209.132.178:443]: connection closed
Apr 27 20:26:22 cd44093 redsocks[1388]: 1619555182.627529 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:51074->3.216.122.111:443]: connection closed
Apr 27 20:26:23 cd44093 redsocks[1388]: 1619555183.202435 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:51078->3.216.122.111:443]: accepted
Apr 27 20:26:25 cd44093 redsocks[1388]: 1619555185.304878 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:57140->52.55.60.119:443]: accepted
Apr 27 20:26:25 cd44093 redsocks[1388]: 1619555185.532929 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:51078->3.216.122.111:443]: connection closed
Apr 27 20:26:28 cd44093 redsocks[1388]: 1619555188.132225 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:51086->3.216.122.111:443]: accepted
Apr 27 20:26:28 cd44093 redsocks[1388]: 1619555188.305990 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:57140->52.55.60.119:443]: connection closed
Apr 27 20:26:30 cd44093 redsocks[1388]: 1619555190.996780 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:51090->3.216.122.111:443]: accepted
Apr 27 20:26:31 cd44093 redsocks[1388]: 1619555191.331572 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:51086->3.216.122.111:443]: connection closed
Apr 27 20:26:33 cd44093 redsocks[1388]: 1619555193.451108 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:59586->18.209.132.178:443]: accepted
Apr 27 20:26:33 cd44093 redsocks[1388]: 1619555193.529610 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:56356->54.230.183.73:443]: accepted
Apr 27 20:26:33 cd44093 redsocks[1388]: 1619555193.766358 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:51090->3.216.122.111:443]: connection closed
Apr 27 20:26:35 cd44093 redsocks[1388]: 1619555195.356339 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:59586->18.209.132.178:443]: connection closed
Apr 27 20:26:36 cd44093 redsocks[1388]: 1619555196.830210 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:56356->54.230.183.73:443]: connection closed
Apr 27 20:26:37 cd44093 redsocks[1388]: 1619555197.460958 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:53476->34.195.215.199:443]: accepted
Apr 27 20:26:40 cd44093 redsocks[1388]: 1619555200.015930 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:52254->54.230.183.39:443]: accepted
Apr 27 20:26:40 cd44093 redsocks[1388]: 1619555200.277127 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:53476->34.195.215.199:443]: connection closed
Apr 27 20:29:13 cd44093 balenad[1338]: time="2021-04-27T20:29:13.625059183Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/d08c86789cf33980df2b5a0a331b3edb9502e90c239f5b3ae920a6eec6fc582b.sock debug=false pid=3677
Apr 27 20:29:15 cd44093 balenad[1338]: time="2021-04-27T20:29:15.687920954Z" level=info msg="shim reaped" id=92f5b27e63950294e769e9afa0bbc69796c773ae74926c5f168b029b0d171be3
Apr 27 20:29:15 cd44093 balenad[1338]: time="2021-04-27T20:29:15.696738778Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:30:59 cd44093 3cdca6b90c30[1338]: [debug] Attempting container log timestamp flush...
Apr 27 20:30:59 cd44093 resin-supervisor[1727]: [debug] Attempting container log timestamp flush...
Apr 27 20:30:59 cd44093 3cdca6b90c30[1338]: [debug] Container log timestamp flush complete
Apr 27 20:30:59 cd44093 resin-supervisor[1727]: [debug] Container log timestamp flush complete
Apr 27 20:30:59 cd44093 resin-supervisor[1727]: [api] GET /v1/healthy 200 - 16.396 ms
Apr 27 20:30:59 cd44093 3cdca6b90c30[1338]: [api] GET /v1/healthy 200 - 16.396 ms
Apr 27 20:32:17 cd44093 balenad[1338]: time="2021-04-27T20:32:17.156587566Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/1648fe6353c6bfaebd026151f7ed753d986bf71ce8c80e3bb7cbb49bcee850b0.sock debug=false pid=3933
Apr 27 20:32:19 cd44093 balenad[1338]: time="2021-04-27T20:32:19.346523434Z" level=info msg="shim reaped" id=9313eb2b026389b1503a825b1e1a0e77425fa41db5f8c685dfebfde191feb65f
Apr 27 20:32:19 cd44093 balenad[1338]: time="2021-04-27T20:32:19.353011633Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:35:20 cd44093 balenad[1338]: time="2021-04-27T20:35:20.765167205Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/980f6a865d7d2429276988c599e36d459e2e3447e68c89181d05efbafa4c2b3c.sock debug=false pid=4087
Apr 27 20:35:22 cd44093 balenad[1338]: time="2021-04-27T20:35:22.882475442Z" level=info msg="shim reaped" id=ae8c48bba3d115304c77aa7fc0f245aa8f174e55ca7a6fc33c2dbbcef0bae2af
Apr 27 20:35:22 cd44093 balenad[1338]: time="2021-04-27T20:35:22.891723472Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:36:00 cd44093 resin-supervisor[1727]: [api] GET /v1/healthy 200 - 5.970 ms
Apr 27 20:36:00 cd44093 3cdca6b90c30[1338]: [api] GET /v1/healthy 200 - 5.970 ms
Apr 27 20:38:24 cd44093 balenad[1338]: time="2021-04-27T20:38:24.325710193Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/17770dac638e08a64aee59e2c5c50cef53a36bcd90823ced2cdf46e0570c32d6.sock debug=false pid=4335
Apr 27 20:38:26 cd44093 balenad[1338]: time="2021-04-27T20:38:26.429178182Z" level=info msg="shim reaped" id=5644e546c37a891dababee2c2737130837cfc64482ba7f10e3da4d4ee867ac60
Apr 27 20:38:26 cd44093 balenad[1338]: time="2021-04-27T20:38:26.436612626Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:40:18 cd44093 sshd[4451]: error: Could not load host key: /etc/ssh/hostkeys/ssh_host_dsa_key
Apr 27 20:40:21 cd44093 sshd[4451]: Accepted publickey for root from 10.253.1.204 port 31263 ssh2: RSA SHA256:eOTg1eCVsaImU+sXoErVsOh5d0CQJQ9sGot46OWtm+0
Apr 27 20:40:59 cd44093 resin-supervisor[1727]: [debug] Attempting container log timestamp flush...
Apr 27 20:40:59 cd44093 resin-supervisor[1727]: [debug] Container log timestamp flush complete
Apr 27 20:40:59 cd44093 3cdca6b90c30[1338]: [debug] Attempting container log timestamp flush...
Apr 27 20:40:59 cd44093 3cdca6b90c30[1338]: [debug] Container log timestamp flush complete
Apr 27 20:41:01 cd44093 3cdca6b90c30[1338]: [api] GET /v1/healthy 200 - 12.192 ms
Apr 27 20:41:01 cd44093 resin-supervisor[1727]: [api] GET /v1/healthy 200 - 12.192 ms
Apr 27 20:41:27 cd44093 balenad[1338]: time="2021-04-27T20:41:27.826119137Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/4dcd7f04213b88556b0adb61b352c1c46c75aeb14982b4857c1e1bf6b2511965.sock debug=false pid=4612
Apr 27 20:41:29 cd44093 balenad[1338]: time="2021-04-27T20:41:29.881084955Z" level=info msg="shim reaped" id=5b40ca458710f0b130b55a466cc6bec61329cbbc7bb5baba67231d70fdc63b62
Apr 27 20:41:29 cd44093 balenad[1338]: time="2021-04-27T20:41:29.888807315Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:42:17 cd44093 redsocks[1388]: 1619556137.209076 info redsocks.c:1254 redsocks_accept_client(...) [10.128.34.172:55820->107.20.209.223:443]: accepted
Apr 27 20:42:20 cd44093 redsocks[1388]: 1619556140.570795 info redsocks.c:682 redsocks_drop_client(...) [10.128.34.172:55820->107.20.209.223:443]: connection closed
Apr 27 20:44:31 cd44093 balenad[1338]: time="2021-04-27T20:44:31.281516155Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/e54dfb437cc4becc88048f3c96d0eaf4f8316b7be54afd2e1e63588942e6ae46.sock debug=false pid=4771
Apr 27 20:44:33 cd44093 balenad[1338]: time="2021-04-27T20:44:33.366441417Z" level=info msg="shim reaped" id=742990b97c11a600a6f1d1c970ae247b02081cfa0821a57448b518a2f2e73cc6
Apr 27 20:44:33 cd44093 balenad[1338]: time="2021-04-27T20:44:33.374457630Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:46:02 cd44093 3cdca6b90c30[1338]: [api] GET /v1/healthy 200 - 12.172 ms
Apr 27 20:46:02 cd44093 resin-supervisor[1727]: [api] GET /v1/healthy 200 - 12.172 ms
Apr 27 20:47:34 cd44093 balenad[1338]: time="2021-04-27T20:47:34.663170286Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/989da931446f72b4258f6f5093fa59451e4d565b972d82c681c1213f6d32dd54.sock debug=false pid=5015
Apr 27 20:47:36 cd44093 balenad[1338]: time="2021-04-27T20:47:36.767606187Z" level=info msg="shim reaped" id=18962191da58e54888ab8c1fa5c9255664879d26219759718982f4ee3eebde46
Apr 27 20:47:36 cd44093 balenad[1338]: time="2021-04-27T20:47:36.778551292Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Apr 27 20:50:38 cd44093 balenad[1338]: time="2021-04-27T20:50:38.198415891Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/02070580bc6fc5c38730a8515786041e573355b1b45d0008f7707566f598ce56.sock debug=false pid=5172
Apr 27 20:50:40 cd44093 balenad[1338]: time="2021-04-27T20:50:40.244770447Z" level=info msg="shim reaped" id=49b3769d361d5ac687f9348a2a11b967cd4f724682edae0949a07cb932a83737
Apr 27 20:50:40 cd44093 balenad[1338]: time="2021-04-27T20:50:40.252312756Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
