I’m trying to setup openBalena on a VPS.
I’m using a SSL/TLS certificate provided by the VPS provider.
After booting a device (QEMU x86-64) when I run balena devices I see the device listed as below:
ID UUID DEVICE NAME DEVICE TYPE FLEET STATUS IS ONLINE SUPERVISOR VERSION OS VERSION DASHBOARD URL
1 **<redacted>** frosty-mountain qemux86-64 admin/myfleet Idle false 12.10.3 balenaOS 2.83.18+rev5 https://dashboard.openbalena-**<redacted>**/devices/**<redacted>**/summary
The device never becomes online.
In trying to debug the issue I found the following messages repeatedly printed in the journalctl logs:
May 23 09:13:28 0512bd9 agetty[1607]: /dev/ttyS1: not a tty
May 23 09:13:29 0512bd9 openvpn[882]: Mon May 23 09:13:29 2022 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
May 23 09:13:29 0512bd9 openvpn[882]: Mon May 23 09:13:29 2022 TCP/UDP: Preserving recently used remote address: [AF_INET]**<REDACTED_IP_ADDRESS>**:443
May 23 09:13:29 0512bd9 openvpn[882]: Mon May 23 09:13:29 2022 Socket Buffers: R=[131072->131072] S=[16384->16384]
May 23 09:13:29 0512bd9 openvpn[882]: Mon May 23 09:13:29 2022 Attempting to establish TCP connection with [AF_INET]**<REDACTED_IP_ADDRESS>**:443 [nonblock]
May 23 09:13:30 0512bd9 openvpn[882]: Mon May 23 09:13:30 2022 TCP connection established with [AF_INET]**<REDACTED_IP_ADDRESS>**:443
May 23 09:13:30 0512bd9 openvpn[882]: Mon May 23 09:13:30 2022 TCP_CLIENT link local: (not bound)
May 23 09:13:30 0512bd9 openvpn[882]: Mon May 23 09:13:30 2022 TCP_CLIENT link remote: [AF_INET]**<REDACTED_IP_ADDRESS>**:443
May 23 09:13:30 0512bd9 openvpn[882]: Mon May 23 09:13:30 2022 WARNING: Bad encapsulated packet length from peer (18516), which must be > 0 and <= 1627 -- please ensure that --tun-mtu or --link-mtu is e>
May 23 09:13:30 0512bd9 openvpn[882]: Mon May 23 09:13:30 2022 Connection reset, restarting [0]
May 23 09:13:30 0512bd9 openvpn[882]: Mon May 23 09:13:30 2022 SIGUSR1[soft,connection-reset] received, process restarting
May 23 09:13:30 0512bd9 openvpn[882]: Mon May 23 09:13:30 2022 Restart pause, 20 second(s)
Can you please help me resolve this issue?
