I followed the quickstart guide to setup openBalena server locally, after installing i.e step - ./scripts/compose up -d I saw everything running. I could see containers, but when I ran https://localhost I am not seeing ‘503 Service Unavailable’. I was expecting a login page to come up for the server, is it not the case ? or am I missing something ?
I am pretty new too but, from the little I know, open balena doesn’t offer a web UI.
You can handle it using balena-CLI or building your own UI using balena-sdk
@pei openBalena doesn’t have an user interface like balenaCloud.
You can only manage it via command-line., but you can develop your own UI, which will need to interface the command-line to a graphic display of your choice.
