Actually I’m not just new to balena but to docker too, so it is like a blind and deaf guy trying to land with a Boeing 747, but after some patching, it seems to run fine.
I’ve started with the 3.8.0 so I went with the versions included in, namely:
open-balena-api-0.209.2
open-balena-db-5.1.2
open-balena-registry-2.25.3
open-balena-s3-2.13.10
open-balena-vpn-11.4.6
For some reason, the dockerfile in:
open-balena-registry-2.25.3 requires open-balena-base:v13.3.2
open-balena-s3-2.13.10 requires open-balena-base:v13.4.0
open-balena-vpn-11.4.6 requires open-balena-base:v13.3.1
and since I wasn’t really knowing what does what, I’ve built all 3 base image - where I had to “backport” the arm64 “awareness” (confd/nodejs) which are already in v14.1.3
I also had to add “ARG TARGETARCH” in “open-balena-s3-2.13.10”, also fix that the “GO_SHA256” variable is for the amd64 image.
(Question: is there any importance to check the sha256 here? It is not checked at the confd/nodejs download…)
I don’t know how to check if things are working, I’m trying to build the CLI, where npm install balena-cli still gives a lot of
22062 warn tar ENOENT: no such file or directory, open '/root/.nvm/versions/node/v12.22.12/lib/node_modules/.staging/fs-extra-2ed77084/lib/empty/index.js'
22063 warn tar ENOENT: no such file or directory, open '/root/.nvm/versions/node/v12.22.12/lib/node_modules/.staging/type-fest-8396db36/ts41/snake-case.d.ts'
22064 warn tar ENOENT: no such file or directory, open '/root/.nvm/versions/node/v12.22.12/lib/node_modules/.staging/typed-error-8cc29938/test/mocha.opts'
messages, and:
24063 error Error while executing:
24063 error /usr/bin/git ls-remote -h -t ssh://git@github.com/balena-io-modules/unbzip2-stream.git
[ node.js - npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/node_modules/cordova.git - Stack Overflow ]
# uname -a
Linux infoscreen-balena 5.15.0-1025-oracle #31-Ubuntu SMP Fri Nov 25 17:03:15 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
# ver
Distrib.: Ubuntu 22.04.1 LTS
Kernel: 5.15.0-1025-oracle #31-Ubuntu SMP Fri Nov 25 17:03:15 UTC 2022
Hardware: 1 x ARM Neoverse-N1 r3p1 (1), BogoMIPS: 50.00
# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
8defaf0b2a05 openbalena-haproxy "/docker-entrypoint.…" 6 hours ago Up 6 hours 0.0.0.0:80->80/tcp, :::80->80/tcp, 222/tcp, 3128/tcp, 5432/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp, 6379/tcp openbalena-haproxy-1
28b81c3c1eb2 balena/open-balena-vpn:v11.4.6 "/usr/bin/entry.sh" 6 hours ago Up 6 hours 80/tcp, 443/tcp, 3128/tcp openbalena-vpn-1
ac45f3d24579 balena/open-balena-registry:v2.25.3 "/usr/bin/entry.sh" 6 hours ago Up 6 hours 80/tcp openbalena-registry-1
958837c39b60 balena/open-balena-api:v0.209.2 "/usr/bin/entry.sh" 6 hours ago Up 6 hours 80/tcp openbalena-api-1
bf8b9c38eaba openbalena-cert-provider "/entry.sh /usr/src/…" 6 hours ago Up 6 hours 80/tcp openbalena-cert-provider-1
dac96801f2c6 balena/open-balena-s3:v2.13.10 "/usr/bin/entry.sh" 6 hours ago Up 6 hours 80/tcp openbalena-s3-1
714e2f2e67f3 balena/open-balena-db:v5.1.2 "/balena-entrypoint.…" 6 hours ago Up 6 hours 5432/tcp openbalena-db-1
dbae2c35386d redis:alpine "docker-entrypoint.s…" 6 hours ago Up 6 hours 6379/tcp openbalena-redis-1
# docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
balena/open-balena-vpn v11.4.6 4fea46f805f2 6 hours ago 750MB
<none> <none> d74965a6eff2 6 hours ago 702MB
<none> <none> be9de1c19d6d 6 hours ago 838MB
balena/open-balena-api v0.209.2 50b094c01480 6 hours ago 944MB
balena/open-balena-s3 v2.13.10 4f99378c4cf1 6 hours ago 1.52GB
<none> <none> d27c59874b19 6 hours ago 693MB
<none> <none> 39ef1311488e 6 hours ago 693MB
<none> <none> 1a02741c461d 6 hours ago 693MB
<none> <none> 193b88baf440 6 hours ago 693MB
<none> <none> a719fefd43ca 7 hours ago 693MB
balena/open-balena-registry v2.25.3 d32e6c84883c 7 hours ago 719MB
balena/open-balena-db v5.1.2 01ef8cbf9afe 9 hours ago 357MB
balena/open-balena-base v13.4.0 fbbf064b11cd 9 hours ago 693MB
balena/open-balena-base v13.3.2 e64f2cf4d02a 9 hours ago 693MB
balena/open-balena-base v13.3.1 af9d2dc0cf0b 9 hours ago 693MB
openbalena-cert-provider latest 6362d3f847b1 3 days ago 35MB
openbalena-haproxy latest ea6ffc89bfc0 3 days ago 22.8MB
postgres 14 25dc4447751f 5 days ago 357MB
debian bullseye 917ea2fdcbd6 6 days ago 118MB
redis alpine c03be620fd3b 11 days ago 30.3MB
alpine latest d3156fec8bcb 5 weeks ago 7.46MB
