I’m trying to update a build and have come across this error each time I try to update the build.
npm notice created a lockfile as package-lock.json. You should commit this file.
I’ve tried etching a new img and renaming everything but I get the same error on fresh builds?!
Here’s a few more lines f the error;
npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use ‘npm cache verify’ instead.
[Build] npm ERR!
[Build] npm ERR! If you’re sure you want to delete the entire cache, rerun this command with --force.
[Build]
[Build] npm ERR! A complete log of this run can be found in:
[Build] npm ERR! /root/.npm/_logs/2017-06-22T00_31_34_387Z-debug.log
# base-image for node on any machine using a template variable,
# see more about dockerfile templates here: http://docs.resin.io/deployment/docker-templates/
# and about resin base images here: http://docs.resin.io/runtime/resin-base-images/
# Note the node:slim image doesn't have node-gyp
FROM resin/%%RESIN_MACHINE_NAME%%-node:slim
# use apt-get if you need to install dependencies,
# for instance if you need ALSA sound utils, just uncomment the lines below.
RUN apt-get update && apt-get install -yq \
python-motephat curl && \
# Defines our working directory in container
WORKDIR /usr/src/app
# Copies the package.json first for better cache on later pushes
COPY package.json package.json
# This install npm dependencies on the resin.io build server,
# making sure to clean up the artifacts it creates in order to reduce the image size.
RUN JOBS=MAX npm install --production --unsafe-perm && npm cache verify && rm -rf /tmp/*
# This will copy all files in our root to the working directory in the container
COPY . ./
# Enable systemd init system in container
ENV INITSYSTEM on
# server.js will run when container starts up on the device
CMD ["python", "lightbox.py"]
I’m still receiving the following notice in the build log; e[34m[Build] e[39m e[91mnpme[0me[91m e[0me[91mnoticee[0me[91m created a lockfile as package-lock.json. You should commit this file.
e[36m[Info] e[39m Starting build for nathanielchang/new1, user nathanielchang
e[36m[Info] e[39m Dashboard link: https://dashboard.resin.io/apps/424280/devices
e[36m[Info] e[39m Building on ‘local’
[==================================================>] 100%
e[32m[Success] e[39m Cached image pulled in 1 second
e[36m[Info] e[39m Dockerfile template application detected
I think you have 2 choices, either ignore the error as your builds are being created successfully or run step 5 locally and commit the package-lock.json file that gets generated. If you go that route you will also need to modify step 4 to copy the file into the build.
