Having trouble installing one of the latest nodes (version 9.11.1).
Everything seems to install but then I get a strange error after, check it out:
[main] npm notice created a lockfile as package-lock.json. You should commit this file.
[main]
[main] npm WARN bos-server@0.0.1 No repository field.
[main]
[main]
[main]
[main] added 556 packages in 27.532s
[main] npm
[main] ERR!
[main] As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead.
[main] npm ERR!
[main]
[main] npm
[main]
[main] ERR!
[main] If you're sure you want to delete the entire cache, rerun this command with --force.
[main]
[main]
[main] npm
[main] ERR!
[main] A complete log of this run can be found in:
[main]
[main] npm
[main] ERR!
[main] /root/.npm/_logs/2018-05-09T21_11_47_317Z-debug.log
[main]
[main] Removing intermediate container ffcaf6495ce1
[main] The command '/bin/sh -c JOBS=MAX npm install --production --unsafe-perm && npm cache clean && rm -rf /tmp/*' returned a non-zero code: 1
[Info] Uploading images
[Error] Service: main
[Error] Error: The command '/bin/sh -c JOBS=MAX npm install --production --unsafe-perm && npm cache clean && rm -rf /tmp/*' returned a non-zero code: 1
Any ideas?
