Noob's question: How does hardware sharing works?
I see, then this is truly a no fix. :confused: .
It is straight forward, and I already get sound out of my DAC, but there’s a subtlety, explained here. In short, there is a certain operation mode or two available for the DAC, that it’s possible to reach only with these firmware files installed. I witnessed this back at the time I used moodeaudio. I also know I should run a certain amixer command.
Awesome :], I have little time to deal with my Raspberry as of now, unfortunately :/, but I’ll do anything necessary when time permits, to get my absolutely declarative and totally reproducible sound system. Hopefully, the balenaSound project will benefit from my testings, and contributions if any will be needed! Cheers :beers:.
P.S (edit): I think the balenaSound project can’t distribute the piano firmware files I mentioned, since their license won’t permit it.
