Hi
my nodejs in windows works great with the serialport nodejs library. when i push it to the fin it fails installing the module
I have encounter this problem before. seems that if i dont create the the nodejs on a linux system it wont work when pushing from windows to linux…
is there a way around this?
> @serialport/bindings@9.2.0 install /usr/src/app/node_modules/@serialport/bindings [main] > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild [main] prebuild-install WARN [main] install No prebuilt binaries found (target=10.24.1 runtime=node arch=arm libc= platform=linux) [main] [main] gyp [main] ERR! [main] find Python [main] [main] [main] gyp [main] ERR! [main] find Python Python is not set from command line or npm configuration [main] [main] gyp [main] ERR! [main] find Python Python is not set from environment variable PYTHON [main] [main] gyp [main] ERR! [main] find Python [main] checking if "python" can be used [main] [main] gyp
