Error on docker build
Hi All,
I have a problem with running node-red-node-serialport what is using node_serialport on a rpi based device.
On building the docker img i get errors like:
[34m[main]e[39m  Step 7/9 : RUN apk add --no-cache make gcc g++ python &&   JOBS=MAX npm install -g node-red-node-serialport --production --silent --unsafe-perm &&   JOBS=MAX npm install -g node-red-contrib-modbus --production --silent --unsafe-perm &&   apk del make gcc g++ python &&   npm cache clean --force && rm -rf /tmp/*
e[34m[main]e[39m   ---> Running in 727dbe264537
e[34m[main]e[39m  fetch http://dl-cdn.alpinelinux.org/alpine/v3.8/main/armhf/APKINDEX.tar.gz
e[34m[main]e[39m  fetch http://dl-cdn.alpinelinux.org/alpine/v3.8/community/armhf/APKINDEX.tar.gz
e[34m[main]e[39m  (1/13) Installing binutils (2.30-r5)
e[34m[main]e[39m  (2/13) Installing isl (0.18-r0)
e[34m[main]e[39m  (3/13) Installing libgomp (6.4.0-r8)
e[34m[main]e[39m  (4/13) Installing libatomic (6.4.0-r8)
e[34m[main]e[39m  (5/13) Installing mpfr3 (3.1.5-r1)
e[34m[main]e[39m  (6/13) Installing mpc1 (1.0.3-r1)
e[34m[main]e[39m  (7/13) Installing gcc (6.4.0-r8)
e[34m[main]e[39m  (8/13) Installing musl-dev (1.1.19-r10)
e[34m[main]e[39m  (9/13) Installing libc-dev (0.7.1-r0)
e[34m[main]e[39m  (10/13) Installing g++ (6.4.0-r8)
e[34m[main]e[39m  (11/13) Installing make (4.2.1-r2)
e[34m[main]e[39m  (12/13) Installing gdbm (1.13-r1)
e[34m[main]e[39m  (13/13) Installing python2 (2.7.15-r0)
e[34m[main]e[39m  Executing busybox-1.28.4-r0.trigger
e[34m[main]e[39m  OK: 205 MiB in 83 packages
e[34m[main]e[39m  make: Entering directory '/usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport/build'
e[34m[main]e[39m    CXX(target) Release/obj.target/serialport/src/serialport.o
e[34m[main]e[39m    CXX(target) Release/obj.target/serialport/src/serialport_unix.o
e[34m[main]e[39m    CXX(target) Release/obj.target/serialport/src/poller.o
e[34m[main]e[39m    CXX(target) Release/obj.target/serialport/src/serialport_linux.o
e[34m[main]e[39m  e[91m../src/serialport_linux.cpp:4:24: fatal error: asm/ioctls.h: No such file or directory
e[34m[main]e[39m   #include <asm/ioctls.h>
e[34m[main]e[39m                          ^
e[34m[main]e[39m  compilation terminated.
e[34m[main]e[39m  e[0m
e[34m[main]e[39m  e[91mmake: *** [serialport.target.mk:96: Release/obj.target/serialport/src/serialport_linux.o] Error 1
e[34m[main]e[39m  make: *** Waiting for unfinished jobs....
e[34m[main]e[39m  e[91m../src/serialport_unix.cpp:24:26: fatal error: linux/serial.h: No such file or directory
e[34m[main]e[39m   #include <linux/serial.h>
e[34m[main]e[39m                            ^
e[34m[main]e[39m  e[91mmake: *** [serialport.target.mk:96: Release/obj.target/serialport/src/serialport_unix.o] Error 1
e[34m[main]e[39m  e[91m../src/serialport.cpp: In function 'void EIO_AfterOpen(uv_work_t*)':
e[34m[main]e[39m  ../src/serialport.cpp:95:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
e[34m[main]e[39m     data->callback.Call(2, argv);
e[34m[main]e[39m                                ^
e[34m[main]e[39m  In file included from ../src/./serialport.h:6:0,
e[34m[main]e[39m                   from ../src/serialport.cpp:1:
e[34m[main]e[39m  ../../nan/nan.h:1618:3: note: declared here
e[34m[main]e[39m     Call(int argc, v8::Local<v8::Value> argv[]) const {
e[34m[main]e[39m     ^~~~
e[34m[main]e[39m  e[91m../src/serialport.cpp: In function 'void EIO_AfterUpdate(uv_work_t*)':
e[34m[main]e[39m  ../src/serialport.cpp:150:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
e[34m[main]e[39m     data->callback.Call(1, argv);
e[34m[main]e[39m                                ^
e[34m[main]e[39m  e[91m../src/poller.cpp: In static member function 'static void Poller::onData(uv_poll_t*, int, int)':
e[34m[main]e[39m  ../src/poller.cpp:69:29: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
e[34m[main]e[39m     obj->callback.Call(2, argv);
e[34m[main]e[39m                               ^
e[34m[main]e[39m  In file included from ../src/poller.cpp:1:0:
e[34m[main]e[39m  e[91m../src/serialport.cpp: In function 'void EIO_AfterClose(uv_work_t*)':
e[34m[main]e[39m  ../src/serialport.cpp:188:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
e[34m[main]e[39m                                ^
e[34m[main]e[39m  e[91m../src/serialport.cpp: In function 'void EIO_AfterFlush(uv_work_t*)':
e[34m[main]e[39m  ../src/serialport.cpp:231:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
e[34m[main]e[39m                                ^
e[34m[main]e[39m  e[91m../src/serialport.cpp: In function 'void EIO_AfterSet(uv_work_t*)':
e[34m[main]e[39m  ../src/serialport.cpp:285:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
e[34m[main]e[39m                                ^
e[34m[main]e[39m  e[91m../src/serialport.cpp: In function 'void EIO_AfterGet(uv_work_t*)':
e[34m[main]e[39m  ../src/serialport.cpp:336:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
e[34m[main]e[39m                                ^
e[34m[main]e[39m  e[91m../src/serialport.cpp: In function 'void EIO_AfterGetBaudRate(uv_work_t*)':
e[34m[main]e[39m  ../src/serialport.cpp:383:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
e[34m[main]e[39m                                ^
e[34m[main]e[39m  e[91m../src/serialport.cpp: In function 'void EIO_AfterDrain(uv_work_t*)':
e[34m[main]e[39m  ../src/serialport.cpp:424:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
e[34m[main]e[39m                                ^
e[34m[main]e[39m  make: Leaving directory '/usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport/build'
e[34m[main]e[39m  Removing intermediate container 727dbe264537
e[34m[main]e[39m  e[31mThe command '/bin/sh -c apk add --no-cache make gcc g++ python &&   JOBS=MAX npm install -g node-red-node-serialport --production --silent --unsafe-perm &&   JOBS=MAX npm install -g node-red-contrib-modbus --production --silent --unsafe-perm &&   apk del make gcc g++ python &&   npm cache clean --force && rm -rf /tmp/*' returned a non-zero code: 1e[39m
e[36m[Info]e[39m  Uploading images
[================>                                  ] 33%e[2Ke[Ge[32m[Success]e[39m  Successfully uploaded images
e[31m[Error]e[39m  Some services failed to build:
e[31m[Error]e[39m    Service: main
e[31m[Error]e[39m      Error: The command '/bin/sh -c apk add --no-cache make gcc g++ python &&   JOBS=MAX npm install -g node-red-node-serialport --production --silent --unsafe-perm &&   JOBS=MAX npm install -g node-red-contrib-modbus --production --silent --unsafe-perm &&   apk del make gcc g++ python &&   npm cache clean --force && rm -rf /tmp/*' returned a non-zero code: 1
e[31m[Error]e[39m  Not deploying release.
I am using base img:
FROM resin/%%RESIN_MACHINE_NAME%%-alpine-node:9-slim
Is that running an old Nodejs version maybe? Does anyone know how to check this or how i can try to update the nodejs version?
Just tried a new build with:
FROM resin/%%RESIN_MACHINE_NAME%%-alpine-node:0.10.48-slim
but with the same results:
[34m[main]e[39m  Step 1/9 : FROM resin/raspberrypi3-alpine-node:0.10.48-slim
e[34m[main]e[39m   ---> 46a9c2b36740
e[34m[main]e[39m  Step 2/9 : RUN mkdir -p /usr/src/app/
e[34m[main]e[39m   ---> Running in fb26500e3558
e[34m[main]e[39m   ---> ceb6eceab279
e[34m[main]e[39m  Removing intermediate container fb26500e3558
e[34m[main]e[39m  Step 3/9 : WORKDIR /usr/src/app
e[34m[main]e[39m   ---> 2a0412617ae2
e[34m[main]e[39m  Removing intermediate container fe8976e19575
e[34m[main]e[39m  Step 4/9 : COPY ./app ./
e[34m[main]e[39m   ---> 3de0661066b8
e[34m[main]e[39m  Removing intermediate container be9cde7470b2
e[34m[main]e[39m  Step 5/9 : COPY entry.sh /usr/bin/entry.sh
e[34m[main]e[39m   ---> 4e53fa4dbf33
e[34m[main]e[39m  Removing intermediate container ae3d549d9826
e[34m[main]e[39m  Step 6/9 : COPY udev-rules/ /etc/udev/rules.d/
e[34m[main]e[39m   ---> 6f40895ec386
e[34m[main]e[39m  Removing intermediate container ba14080f9d1a
e[34m[main]e[39m  Step 7/9 : RUN apk add --no-cache make gcc g++ python &&   JOBS=MAX npm install -g node-red-node-serialport --production --silent &&   JOBS=MAX npm install -g node-red-contrib-modbus --production --silent &&   apk del make gcc g++ python &&   npm cache clean --force && rm -rf /tmp/*
e[34m[main]e[39m   ---> Running in 47854f1ebb21
e[34m[main]e[39m  e[91m/usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport/node_modules/prebuild-install/node_modules/which-pm-runs/index.js:11
e[34m[main]e[39m  e[91m  const pmSpec = userAgent.split(' ')[0]
e[34m[main]e[39m    ^^^^^
e[34m[main]e[39m  e[91mSyntaxError: Use of const in strict mode.
e[34m[main]e[39m      at Module._compile (module.js:439:25)
e[34m[main]e[39m      at Object.Module._extensions..js (module.js:474:10)
e[34m[main]e[39m      at Module.load (module.js:356:32)
e[34m[main]e[39m      at Function.Module._load (module.js:312:12)
e[34m[main]e[39m      at Module.require (module.js:364:17)
e[34m[main]e[39m      at require (module.js:380:17)
e[34m[main]e[39m      at Object.<anonymous> (/usr/local/lib/node_modules/node-red-node-serialport/node_modules/serialport/node_modules/prebuild-install/bin.js:5:19)
e[34m[main]e[39m      at Module._compile (module.js:456:26)
e[34m[main]e[39m                          ^
e[34m[main]e[39m  e[91mmake: *** [serialport.target.mk:91: Release/obj.target/serialport/src/serialport_linux.o] Error 1
e[34m[main]e[39m                            ^
e[34m[main]e[39m  e[91mmake: *** [serialport.target.mk:91: Release/obj.target/serialport/src/serialport_unix.o] Error 1
e[34m[main]e[39m  e[91m../src/poller.cpp: In constructor 'Poller::Poller(int)':
e[34m[main]e[39m  ../src/poller.cpp:12:39: error: could not convert 'status' from 'int' to 'uv_err_t {aka uv_err_s}'
e[34m[main]e[39m       Nan::ThrowError(uv_strerror(status));
e[34m[main]e[39m                                         ^
e[34m[main]e[39m  e[91m../src/poller.cpp: In member function 'void Poller::poll(int)':
e[34m[main]e[39m  ../src/poller.cpp:39:43: error: could not convert 'status' from 'int' to 'uv_err_t {aka uv_err_s}'
e[34m[main]e[39m       Nan::ThrowTypeError(uv_strerror(status));
e[34m[main]e[39m                                             ^
e[34m[main]e[39m  e[91m../src/poller.cpp: In member function 'void Poller::stop()':
e[34m[main]e[39m  ../src/poller.cpp:47:43: error: could not convert 'status' from 'int' to 'uv_err_t {aka uv_err_s}'
e[34m[main]e[39m                                             ^
e[34m[main]e[39m  ../src/poller.cpp:58:75: error: could not convert 'status' from 'int' to 'uv_err_t {aka uv_err_s}'
e[34m[main]e[39m       argv[0] = v8::Exception::Error(Nan::New<v8::String>(uv_strerror(status)).ToLocalChecked());
e[34m[main]e[39m        ^
e[34m[main]e[39m  e[91m../src/poller.cpp:69:29: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
e[34m[main]e[39m                               ^
e[34m[main]e[39m  ../node_modules/nan/nan.h:1618:3: note: declared here
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m  e[91mmake: *** [serialport.target.mk:91: Release/obj.target/serialport/src/poller.o] Error 1
e[34m[main]e[39m  Removing intermediate container 47854f1ebb21
e[34m[main]e[39m  e[31mThe command '/bin/sh -c apk add --no-cache make gcc g++ python &&   JOBS=MAX npm install -g node-red-node-serialport --production --silent &&   JOBS=MAX npm install -g node-red-contrib-modbus --production --silent &&   apk del make gcc g++ python &&   npm cache clean --force && rm -rf /tmp/*' returned a non-zero code: 1e[39m
e[31m[Error]e[39m      Error: The command '/bin/sh -c apk add --no-cache make gcc g++ python &&   JOBS=MAX npm install -g node-red-node-serialport --production --silent &&   JOBS=MAX npm install -g node-red-contrib-modbus --production --silent &&   apk del make gcc g++ python &&   npm cache clean --force && rm -rf /tmp/*' returned a non-zero code: 1
Has anyone an idea how to get it all working again :frowning:
From the first build output, it looks like you’re not including the headers that it will need to build. I suspect adding linux-headers to your apk add line will rectify this.
Best regards, Heds
Hi yes, i noticed this aswell and tried it just now and the result is no fatal error, but still a failed build :frowning:
e[34m[main]e[39m  Step 7/9 : RUN apk add --no-cache make gcc g++ python linux-headers udev &&   JOBS=MAX npm install -g node-red-node-serialport --unsafe-perm --build-from-source --production --silent &&   JOBS=MAX npm install -g node-red-contrib-modbus --unsafe-perm --build-from-source --production --silent &&   apk del make gcc g++ python &&   npm cache clean --force && rm -rf /tmp/*
e[34m[main]e[39m   ---> Running in f8029267be99
e[34m[main]e[39m  (1/14) Installing binutils (2.30-r5)
e[34m[main]e[39m  (2/14) Installing isl (0.18-r0)
e[34m[main]e[39m  (3/14) Installing libgomp (6.4.0-r8)
e[34m[main]e[39m  (4/14) Installing libatomic (6.4.0-r8)
e[34m[main]e[39m  (5/14) Installing mpfr3 (3.1.5-r1)
e[34m[main]e[39m  (6/14) Installing mpc1 (1.0.3-r1)
e[34m[main]e[39m  (7/14) Installing gcc (6.4.0-r8)
e[34m[main]e[39m  (8/14) Installing musl-dev (1.1.19-r10)
e[34m[main]e[39m  (9/14) Installing libc-dev (0.7.1-r0)
e[34m[main]e[39m  (10/14) Installing g++ (6.4.0-r8)
e[34m[main]e[39m  (11/14) Installing linux-headers (4.4.6-r2)
e[34m[main]e[39m  (12/14) Installing make (4.2.1-r2)
e[34m[main]e[39m  (13/14) Installing gdbm (1.13-r1)
e[34m[main]e[39m  (14/14) Installing python2 (2.7.15-r0)
e[34m[main]e[39m  OK: 208 MiB in 84 packages
e[34m[main]e[39m                                         ^
e[34m[main]e[39m                                             ^
e[34m[main]e[39m                                             ^
e[34m[main]e[39m        ^
e[34m[main]e[39m                               ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m                                ^
e[34m[main]e[39m  Removing intermediate container f8029267be99
e[34m[main]e[39m  e[31mThe command '/bin/sh -c apk add --no-cache make gcc g++ python linux-headers udev &&   JOBS=MAX npm install -g node-red-node-serialport --unsafe-perm --build-from-source --production --silent &&   JOBS=MAX npm install -g node-red-contrib-modbus --unsafe-perm --build-from-source --production --silent &&   apk del make gcc g++ python &&   npm cache clean --force && rm -rf /tmp/*' returned a non-zero code: 1e[39m
e[31m[Error]e[39m      Error: The command '/bin/sh -c apk add --no-cache make gcc g++ python linux-headers udev &&   JOBS=MAX npm install -g node-red-node-serialport --unsafe-perm --build-from-source --production --silent &&   JOBS=MAX npm install -g node-red-contrib-modbus --unsafe-perm --build-from-source --production --silent &&   apk del make gcc g++ python &&   npm cache clean --force && rm -rf /tmp/*' returned a non-zero code: 1
@hedss Do you have an idea what else can be wrong?
This is because the version of Node that you’re inheriting from in the base image does not support ECMAScript 6 extensions. The LTS version of Node is 8.11.3, and I’d suggest using a version of the base image using this version.
You can find a full list of base image tags for NodeJS on Alpine for RPi3 here: https://hub.docker.com/r/resin/raspberrypi3-alpine-node/tags/
Best regards, Heds
@hedss Ahh you are my hero! It works! :smiley:
I used the suggested img rapberrypi3-alpine:8.11.3 and now it does build again!
You really made my day and the upcoming weekend :smile:
Thnx!
You’re welcome, glad to be of assistance! :slight_smile:
