When running Starter images, wifi-connect was working fine for me. I started to move into deployment with my first 20 systems and wifi-connect stopped working! The application is now Essentials. Nothing has indicated to me that dbus should stop working, but this is the error message I get from wifi-connect:
root@b18d456:/usr/src/app# ./wifi-connect
Cannot get the NetworkManager service state
thread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: D-Bus error: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory (org.freedesktop.DBus.Error.FileNotFound)', /checkout/src/libcore/result.rs:906:4
note: Run with `RUST_BACKTRACE=1` for a backtrace.
It looks like D-Bus setup failed: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory is the same issue.
However, looking at my docker-compose.yml, it seems it should be fine:
version: '2.1'
networks: {}
volumes:
resin-data: {}
services:
main:
build:
context: .
privileged: true
tty: true
restart: always
network_mode: host
volumes:
- 'resin-data:/data'
labels:
io.resin.features.kernel-modules: '1'
io.resin.features.firmware: '1'
io.resin.features.dbus: '1'
io.resin.features.supervisor-api: '1'
io.resin.features.resin-api: '1'
What’s going on here?
