OS: balenaOS 2.50.1+rev1
Base Image: balenalib/%%BALENA_MACHINE_NAME%%-node:12-run (intel-nuc)
Application is based on:
Device: Intel Nuc
I have been unable to get any audio output through HDMI or 3.5 Jack. I have attempted to use speaker-test, aplay & playing a video without success. I was able to previously create an .asoundrc file with specific hardcoded values that allowed audio to play through HDMI however this isn’t a valid solution due to the application running on many different devices with varying hardware configs.
I’m lead to believe that I shouldn’t have to do any configuration at all in order to get the sound working.
Previously working configuration ($HOME/.asoundrc):
pcm.!default {
type hw
card 0
device 3
ctl.!default {
type hw
card 0
device 3
aplay -L output:
null
Discard all samples (playback) or generate zero samples (capture)
sysdefault:CARD=PCH
HDA Intel PCH, ALC283 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front speakers
surround21:CARD=PCH,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
hdmi:CARD=PCH,DEV=0
HDA Intel PCH, HDMI 0
HDMI Audio Output
hdmi:CARD=PCH,DEV=1
HDA Intel PCH, HDMI 1
HDMI Audio Output
hdmi:CARD=PCH,DEV=2
HDA Intel PCH, HDMI 2
HDMI Audio Output
hdmi:CARD=PCH,DEV=3
HDA Intel PCH, HDMI 3
HDMI Audio Output
hdmi:CARD=PCH,DEV=4
HDA Intel PCH, HDMI 4
HDMI Audio Output
dmix:CARD=PCH,DEV=0
Direct sample mixing device
dmix:CARD=PCH,DEV=3
dmix:CARD=PCH,DEV=7
dmix:CARD=PCH,DEV=8
dmix:CARD=PCH,DEV=9
dmix:CARD=PCH,DEV=10
dsnoop:CARD=PCH,DEV=0
Direct sample snooping device
dsnoop:CARD=PCH,DEV=3
dsnoop:CARD=PCH,DEV=7
dsnoop:CARD=PCH,DEV=8
dsnoop:CARD=PCH,DEV=9
dsnoop:CARD=PCH,DEV=10
hw:CARD=PCH,DEV=0
Direct hardware device without any conversions
hw:CARD=PCH,DEV=3
hw:CARD=PCH,DEV=7
hw:CARD=PCH,DEV=8
hw:CARD=PCH,DEV=9
hw:CARD=PCH,DEV=10
plughw:CARD=PCH,DEV=0
Hardware device with all software conversions
plughw:CARD=PCH,DEV=3
plughw:CARD=PCH,DEV=7
plughw:CARD=PCH,DEV=8
plughw:CARD=PCH,DEV=9
plughw:CARD=PCH,DEV=10
ls /dev/snd:
by-path pcmC0D0c pcmC0D10p pcmC0D7p pcmC0D9p
controlC0 pcmC0D0p pcmC0D3p pcmC0D8p timer
