So I followed this tutorial to make a Minecraft server. I have been recently have the issue of connecting to my WinSCP server files. I have been getting this error.
I contacted the tutorial creator and he said to make a forum here because it might be due to the new dashboard changes.Hello @Pickle,
Welcome to our forums! When is this issue manifesting? Does it happen when you try to access via WinSCP? Can you connect via SCP or not?
Cheers,
Nico.
I can not connect to WinSCp at all, it just fails to connect.
Hi Rory
- Looks like the device is online and has been assigned an IP - so the device side things seem fine to me. Did you also have the same results with a Development image instead of the Production?
- Can you confirm that your device is on the same network when you try to connect using scp as per the blog?
Its fixed now I think I was on my guest network by mistake.
