Hi!
How can I deploy to devices an old release? I mean, how to change “current” release choosing one from those previously uploaded.
Thanks so much.
Hi!
Thanks so much.
Hey, check out our staged release feature, you can use it via the SDK: https://www.balena.io/docs/reference/sdk/node-sdk/#balena.models.application.pinToRelease / https://www.balena.io/docs/reference/sdk/node-sdk/#balena.models.device.pinToRelease or via bash scripts: https://github.com/balena-io-projects/staged-releases and it will allow you to target your entire application to a particular release (you will probably want to disable auto-tracking of latest releases in that case) or point individual devices to specific releases, overriding the app level release.
