We’re currently struggling with the network_mode: service:[name] which causes HTTP 400 errors when checking the journalctl -f --lines=100 -u balena -a output:
May 30 19:12:10 97fadcc e518b461e71b[1160]: [event] Event: Service install {"service":{"appId":2053583,"serviceId":2165180,"serviceName":"xrdp","commit":"9b002172c046311b09caf288f94ac06e","releaseId":2605677}}
May 30 19:12:10 97fadcc e518b461e71b[1160]: [error] Scheduling another update attempt in 64000ms due to failure: Error: Failed to apply state transition steps. (HTTP code 400) unexpected - conflicting options: port exposing and the container type network mode Steps:["start"]
May 30 19:12:10 97fadcc e518b461e71b[1160]: [error] at fn (/usr/src/app/dist/app.js:6:8594)
May 30 19:12:10 97fadcc e518b461e71b[1160]: [error] at runMicrotasks (<anonymous>)
May 30 19:12:10 97fadcc e518b461e71b[1160]: [error] at processTicksAndRejections (internal/process/task_queues.js:97:5)
May 30 19:12:10 97fadcc e518b461e71b[1160]: [error] Device state apply error Error: Failed to apply state transition steps. (HTTP code 400) unexpected - conflicting options: port exposing and the container type network mode Steps:["start"]
May 30 19:12:31 97fadcc e518b461e71b[1160]: [error] LogBackend: unexpected error: Error: read ECONNRESET
May 30 19:12:31 97fadcc e518b461e71b[1160]: [error] at TLSWrap.onStreamRead (internal/stream_base_commons.js:205:27)
This setup works flawlessly when testing local Docker (Docker Desktop, Windows 10)
vpnclient:
image: "containinger/docker-softether-vpn-client:latest"
container_name: vpnclient
hostname: vpnclient
privileged: true
cap_add:
- NET_ADMIN
restart: always
ports:
- "3389:3389"
labels:
service.name: "vpnclient"
environment:
SE_HUB: DEFAULT
SE_SERVER: "my.vpn.server.com:1234"
SE_USERNAME: <<my-usr>
SE_PASSWORD: <<my-pwd>>
xrdp:
image: piscada/xrdp:latest
privileged: true
shm_size: "1gb"
restart: always
labels:
service.name: "xrdp"
command: ["foo", "bar", "yes" ]
depends_on:
- vpnclient
# use network stack of vpnclient to gain access to
# the VPN network
network_mode: service:vpnclient
