Network interfaces route metric
Hi all!
Your product is amazing, although now we are facing a small challenge in networking.
Context:
Our devices run raspberrypi 3 compute module
2 Ethernet NICs
1 4G modem
balenaOs 5.0.8
Supervisor 15.3.0
When launching the app, we configure the network interfaces this way:
Eth0
var defaultEthernetManual = InterfaceConfig{
	Address:       "192.168.0.100/24",
	Dhcp:          false,
	DNS:           "192.168.0.1",
	Gateway:       "192.168.0.254",
	RouteMetric:   "6",
	Type:          "802-3-ethernet",
	InterfaceName: eth0,
ipv4.method, manual
ipv4.ignore-auto-dns, yes
ipv4.never-default, true
ipv6.method, disabled
Eth1
var defaultEthernetDHCP = InterfaceConfig{
	Dhcp:          true,
	RouteMetric:   "4",
	InterfaceName: "",
ipv4.method, auto
ipv4.route-metric, config.RouteMetric
ipv4.dns, 8.8.8.8 193.136.152.81
ipv4.dns-priority, config.RouteMetric
Cellular
var defaultCellular = InterfaceConfig{
	Dhcp:          true,
	RouteMetric:   "3",
	Type:          "gsm",
	InterfaceName: "cdc-wdm0",
ipv4.method, auto
Situation 1
  • 4G with antenna connected
  • Eth0 and Eth1 connected through a modem with internet access
cdc-wdm0: connected to cellular
“cdc-wdm0”
gsm (option, qmi_wwan), hw, iface wwan0, mtu 1360
ip4 default
inet4 100.75.156.145/30
route4 100.75.156.144/30 metric 3
route4 default via 100.75.156.146 metric 3
supervisor0: connected (externally) to supervisor0
“supervisor0”
bridge, 02:42:B9:0F:BA:6B, sw, mtu 1500
inet4 10.114.104.1/25
route4 10.114.104.0/25 metric 0
inet6 fe80::42:b9ff:fe0f:ba6b/64
route6 fe80::/64 metric 256
eth0: connected to eth0
“eth0”
ethernet (smsc95xx), B8:27:EB:2C:27:83, hw, mtu 1500
inet4 192.168.0.100/24
route4 192.168.0.0/24 metric 6
eth1: connected to eth1
“eth1”
ethernet (smsc95xx), B8:27:EB:64:B7:3A, hw, mtu 1500
inet4 192.168.2.14/24
route4 192.168.2.0/24 metric 4
route4 default via 192.168.2.10 metric 4
Our device prefers the cellular connection as expected.
more info:
cat /etc/resolv.dnsmasq
nameserver 8.8.8.8
nameserver 193.136.152.81
nameserver 192.168.0.1
cat /etc/resolv.conf
we use dnsmasq at 127.0.0.2 so that user containers can run their own dns cache and forwarder and not conflict with dnsmasq on the host
nameserver 127.0.0.2
options timeout:15
nslookup google.com
Server: 127.0.0.2
Address 1: 127.0.0.2 e63bf17
Address 1: 142.250.185.110 fra16s49-in-f14.1e100.net
Address 2: 2a00:1450:4001:830::200e fra24s11-in-x0e.1e100.net
Situation 2
  • took 4G antenna out (lost 4G signal)
  • Eth0 and Eth1 linked to a router with internet access
“eth1”
ip4 default
“supervisor0”
“eth0”
cdc-wdm0: connecting (prepare) to cellular
“cdc-wdm0”
gsm (option, qmi_wwan), hw, mtu 1360
In this case, as expected, it regains internet through the next interface according to the route metric, in this case: Eth1
Situation 3
  • I Reconnect the 4G antenna and it regains internet through the cellular network interface
“cdc-wdm0”
gsm (qmi_wwan, option), hw, iface wwan0, mtu 1360
ip4 default
“supervisor0”
“0424 ec00”
“0424 ec00”
Situation 4
  • I took the 4G antenna (first)
  • and then unplug the internet form the router where the Eth0 and Eth1 are connected and of course the device loses internet connection
  • note that eth0 and eth1 still have ethernet cables connected to a router (without internet access)
“eth1”
ip4 default
“supervisor0”
“eth0”
“cdc-wdm0”
gsm (qmi_wwan, option), hw, mtu 1360
Host
nslookup google.com
Server: 127.0.0.2
Address 1: 10.0.0.1
Address 2: 10.0.0.1
Container
nslookup google.com
Server: 127.0.0.11
Address: 127.0.0.11:53
Address: 10.0.0.1
Address: 10.0.0.1
*Situation *
  • Finally, I connect the 4G antenna and hope the device to reacquire internet connection through the cellular interface, but alas, it doesn’t!
“eth1”
ip4 default
“supervisor0”
“eth0”
“cdc-wdm0”
route4 default via 100.75.156.146 metric 20003
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: connected
| power state: on
| access tech: lte
| signal quality: 60% (recent)
It recognizes and connects to the 4G signal but doesn’t use that interface. It somehow “invented” the route metric 20003.
Any idea for how does this happen and how to avoid it?
Thank you in advance and best regards
Hello @suporte it’s really odd that the route4 default has the metric re-written!
I’m checking the nmcli forums to explore if there is a case there like yours!
Let’s stay connected if you find a solution on this!
Hi @mpous
Thanks for the quick response.
You might find our previous reported issue in this post
And perhaps I should have continued that, instead of creating a new one.
We’re already implementing the suggestions made in that post but something is still missing…
Best regards!
If anyone has some hint on this, I would appreciate a lot.
If someone on the Balena Team’s side needs, we can give access to a device and I can perform the tests (plug cable, unplug cable,…) at the same time
All the best for everyone!
