Need solutiom for recovery data storage
I used balena etcher to my sandisk ssd for uploading windows10 on my mac, i want to remove and make it 256 gb again because it looks like 5,52 gb now. How can i do that? Thanks.
I find it from there Etcher broke my USB stick … or did it?
But don’t know about if isn t it mine ssd is fat32, im a lit bit newbie about those things. Sandisk extreme portable ssd 500gb is fat32?
Hi @markaa!
If I’m understanding your post correctly, you’re running MacOS and looking to check if the SSD you want to format is FAT32 or not?
If I have that right, then I would recommend using the Disk Utility in MacOS. In my screenshot, I only have my main drive listed, so it’s in APFS format, but on the left you can see that there are options to select. You’ll want to find the SSD you’re connecting from that list, and from there it should show you whether the format is APFS, FAT32, exFAT, or something else.
Let us know if that works for you, or if you were actually looking for help with something else and I’ve misunderstood!
A file has been uploaded using Jellyfish: Jellyfish
