I’m using the new multicontainer feature.
I’ve successfully built and deployed my microservices using the docker-compose below and everything is fine except for a volume mapping.
version: '2'
services:
# some more services
openalpr:
build: ./openalpr
network_mode: "bridge"
labels:
io.resin.features.supervisor-api: '1'
io.resin.features.resin-api: '1'
depends_on:
- mqtt
- supervisor
- redis
volumes:
- /dev/null:/dev/raw1394
The docs specify that the following on volumes:
Only support short syntax and named volumes. Bind mounts are not supported, except for as allowed by resin.io specific labels
The docker-compose-v2 docs say that short syntax is of this format:
The short syntax uses the generic [SOURCE:]TARGET[:MODE] format, where SOURCE can be either a host path or volume name. TARGET is the container path where the volume is mounted. Standard modes are ro for read-only and rw for read-write (default).
Specify an absolute path mapping
- /opt/data:/var/lib/mysql
The example above looks a lot like my /dev/null:/dev/raw1394
Do the docs mean that you only support named volumes in the short syntax?
The problem I’m trying to solve here is the following SO issue:
How would I go about this?
Thanks in advance!
