Hi!
I am trying to connect a Huawei MS2372 Cellular Modem to my RPi 3B.
This works to some extent, as I have been able to ping 8.8.8.8 and connect to the device from the dashboard. However, after a few minutes (or seconds), it brakes, network manager reports no modem found:
root@44ca790:~# mmcli -L
No modems were found
Why doesn’t my modem work consistently?
The usb device is found, and it appears to not be a mode switching issue
since this command root@44ca790:~# usb-devices lists the modem:
T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=02 Dev#= 6 Spd=480 MxCh= 0
D: Ver= 2.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=12d1 ProdID=1506 Rev=01.02
S: Manufacturer=HUAWEI_MOBILE
S: Product=HUAWEI_MOBILE
C: #Ifs= 4 Cfg#= 1 Atr=80 MxPwr=2mA
I: If#=0x0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=01 Driver=option
I: If#=0x1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=02 Prot=03 Driver=option
I: If#=0x2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=02 Prot=12 Driver=option
I: If#=0x3 Alt= 1 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=16 Driver=huawei_cdc_ncm
Here is a snippet from journalctl -u ModemManager:
Sep 17 13:13:03 44ca790 ModemManager[838]: Couldn't find associated cdc-wdm port for 'net/wwan0' Sep 17 13:13:03 44ca790 ModemManager[838]: Modem /org/freedesktop/ModemManager1/Modem/1: 3GPP Registration state changed (registering -> home) Sep 17 13:13:03 44ca790 ModemManager[838]: Modem /org/freedesktop/ModemManager1/Modem/1: state changed (connecting -> connected) Sep 17 13:13:03 44ca790 ModemManager[838]: Simple connect state (8/8): All done Sep 17 13:13:10 44ca790 ModemManager[838]: (net/wlan0): released by device '/sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1' Sep 17 13:13:10 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1': Operation was cancelled Sep 17 13:13:10 44ca790 ModemManager[838]: (usbmisc/cdc-wdm0): released by device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' Sep 17 13:13:10 44ca790 ModemManager[838]: (net/wwan0): released by device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' Sep 17 13:13:10 44ca790 ModemManager[838]: (tty/ttyUSB0): released by device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' Jan 06 13:03:16 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1': not supported by any plugin Jan 06 13:03:16 44ca790 ModemManager[838]: (tty/ttyUSB2): released by device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' Jan 06 13:03:16 44ca790 ModemManager[838]: (tty/ttyUSB1): released by device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' Jan 06 13:04:29 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1': not supported by any plugin Jan 06 13:04:29 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1': not supported by any plugin Jan 06 13:04:42 44ca790 ModemManager[838]: (net/wlan0): released by device '/sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1' Jan 06 13:04:42 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1': Operation was cancelled Jan 06 13:04:44 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1': not supported by any plugin Jan 06 13:04:47 44ca790 ModemManager[838]: [device /sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3] creating modem with plugin 'Huawei' and '5' ports Jan 06 13:04:47 44ca790 ModemManager[838]: Could not grab port (tty/ttyUSB1): 'Cannot add port 'tty/ttyUSB1', unhandled serial type' Jan 06 13:04:47 44ca790 ModemManager[838]: Could not grab port (usbmisc/cdc-wdm0): 'Cannot add port 'usbmisc/cdc-wdm0', unsupported' Jan 06 13:04:47 44ca790 ModemManager[838]: Modem for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' successfully created Jan 06 13:04:51 44ca790 ModemManager[838]: couldn't load list of Own Numbers: 'Not found' Jan 06 13:04:51 44ca790 ModemManager[838]: Modem: state changed (unknown -> disabled) Jan 06 13:04:51 44ca790 ModemManager[838]: Modem /org/freedesktop/ModemManager1/Modem/2: state changed (disabled -> enabling) Jan 06 13:04:51 44ca790 ModemManager[838]: Simple connect started... Jan 06 13:04:51 44ca790 ModemManager[838]: Simple connect state (4/8): Wait to get fully enabled Jan 06 13:04:52 44ca790 ModemManager[838]: Modem /org/freedesktop/ModemManager1/Modem/2: state changed (enabling -> enabled) Jan 06 13:04:52 44ca790 ModemManager[838]: Simple connect state (5/8): Register Jan 06 13:04:52 44ca790 ModemManager[838]: Modem /org/freedesktop/ModemManager1/Modem/2: 3GPP Registration state changed (unknown -> registering) Jan 06 13:04:52 44ca790 ModemManager[838]: Simple connect state (6/8): Bearer Jan 06 13:04:52 44ca790 ModemManager[838]: Simple connect state (7/8): Connect Jan 06 13:04:52 44ca790 ModemManager[838]: Modem /org/freedesktop/ModemManager1/Modem/2: state changed (enabled -> connecting) Jan 06 13:04:52 44ca790 ModemManager[838]: Couldn't find associated cdc-wdm port for 'net/wwan0' Jan 06 13:04:52 44ca790 ModemManager[838]: Modem /org/freedesktop/ModemManager1/Modem/2: 3GPP Registration state changed (registering -> home) Jan 06 13:04:52 44ca790 ModemManager[838]: Modem /org/freedesktop/ModemManager1/Modem/2: state changed (connecting -> connected) Jan 06 13:04:52 44ca790 ModemManager[838]: Simple connect state (8/8): All done Jan 06 13:04:59 44ca790 ModemManager[838]: (net/wlan0): released by device '/sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1' Jan 06 13:04:59 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1': Operation was cancelled Jan 06 13:05:01 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1': not supported by any plugin Jan 06 13:05:02 44ca790 ModemManager[838]: (usbmisc/cdc-wdm0): released by device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' Jan 06 13:05:02 44ca790 ModemManager[838]: (net/wwan0): released by device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' Jan 06 13:05:02 44ca790 ModemManager[838]: (tty/ttyUSB0): released by device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' Jan 06 13:05:02 44ca790 ModemManager[838]: (tty/ttyUSB1): released by device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' Jan 06 13:05:02 44ca790 ModemManager[838]: (tty/ttyUSB2): released by device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' Jan 06 13:06:14 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1': not supported by any plugin Jan 06 13:06:14 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1': not supported by any plugin Jan 06 13:06:30 44ca790 ModemManager[838]: (net/wlan0): released by device '/sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1' Jan 06 13:06:30 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f300000.mmcnr/mmc_host/mmc1/mmc1:0001/mmc1:0001:1': Operation was cancelled Jan 06 13:06:31 44ca790 ModemManager[838]: Couldn't check support for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.1': not supported by any plugin Jan 06 13:06:33 44ca790 ModemManager[838]: [device /sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3] creating modem with plugin 'Huawei' and '5' ports Jan 06 13:06:33 44ca790 ModemManager[838]: Could not grab port (tty/ttyUSB1): 'Cannot add port 'tty/ttyUSB1', unhandled serial type' Jan 06 13:06:33 44ca790 ModemManager[838]: Could not grab port (usbmisc/cdc-wdm0): 'Cannot add port 'usbmisc/cdc-wdm0', unsupported' Jan 06 13:06:33 44ca790 ModemManager[838]: Modem for device '/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3' successfully created
The system connection file:
$ cat system-config/my_cellular
[connection]
id=cellular
type=gsm
autoconnect=true
[gsm]
apn=telia
pin=1234
[serial]
baud=115200
[ipv4]
method=auto
[ipv6]
addr-gen-mode=stable-privacy
method=auto
Is there anything I can try or check to resolve this issue?
