Hey I am looking at reducing the size of our final docker image by using a multistage build to compile openCV:
Currently we have the following steps:
# Install G-Streamer
# https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/accelerated_gstreamer.html#wwpID0E0R40HA
# Note - Keep it as two commands (?)
RUN apt-get update && apt-get install -y gstreamer1.0-tools gstreamer1.0-alsa \
gstreamer1.0-plugins-base gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly \
gstreamer1.0-libav
RUN apt-get install -y libgstreamer1.0-dev \
libgstreamer-plugins-base1.0-dev \
libgstreamer-plugins-good1.0-dev \
libgstreamer-plugins-bad1.0-dev
RUN \
apt-get update && apt-get install -y --no-install-recommends \
cuda-toolkit-10-2 cuda-compiler-10-2 \
lbzip2 xorg-dev \
cmake wget unzip \
libgtk2.0-dev \
libavcodec-dev \
libjpeg-dev \
libpng-dev \
libtiff-dev \
libdc1394-22-dev \
python3 \
python3-dev \
python3-numpy \
network-manager \
avrdude
RUN \
wget https://github.com/opencv/opencv/archive/4.5.4.zip && \
unzip 4.5.4.zip && rm 4.5.4.zip && \
wget https://github.com/opencv/opencv_contrib/archive/4.5.4.zip -O opencv_modules.4.5.4.zip && \
unzip opencv_modules.4.5.4.zip && rm opencv_modules.4.5.4.zip && \
export CUDA_HOME=/usr/local/cuda-10.2/ && \
export LD_LIBRARY_PATH=${CUDA_HOME}/lib64 && \
PATH=${CUDA_HOME}/bin:${PATH} && export PATH && \
mkdir -p opencv-4.5.4/build && cd opencv-4.5.4/build && \
cmake -D WITH_CUDA=ON \
-D CUDA_ARCH_BIN="5.3" \
-D BUILD_LIST=cudev,highgui,videoio,cudaimgproc,ximgproc,python3 \
-D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib-4.5.4/modules \
-D CUDA_ARCH_PTX="" \
-D WITH_GSTREAMER=ON \
-D WITH_LIBV4L=ON \
-D BUILD_TESTS=OFF \
-D BUILD_PERF_TESTS=OFF \
-D BUILD_SAMPLES=OFF \
-D BUILD_EXAMPLES=OFF \
-D CMAKE_BUILD_TYPE=RELEASE \
# -D WITH_JPEG=ON \
# -D BUILD_JPEG=OFF \
# -D JPEG_INCLUDE_DIR=/opt/libjpeg-turbo/include/ \
# -D JPEG_LIBRARIES=/opt/libjpeg-turbo/lib64/ \
# -D JPEG_LIBRARY=/opt/libjpeg-turbo/lib64/libjpeg.a \
-D WITH_GTK=OFF \
-D BUILD_DOCS=OFF \
-D CMAKE_INSTALL_PREFIX=/usr/local .. && \
make -j4 && make install && \
cp /usr/src/app/opencv-4.5.4/build/bin/opencv_version /usr/src/app/ && \
rm -rf /usr/src/app/opencv-4.5.4 && \
rm -rf /usr/src/app/opencv_contrib-4.5.4
Can we just copy opencv-4.5.4/build and add it to the path for it to work as expected? I’m asking before trying it myself, just because the build time is rediculously long.
