managing /tmp/balena/updates.lock
Hi, I used to be able to install a updates.lock using lockfile from within a container to prevent updates.
Suddenly this now fails.
I have checked that my controller still has lockfile installed.
The command that used to work is
lockfile /tmp/balena/updates.lock
It now fails with
lockfile: Try praying, giving up on "/tmp/balena/updates.lock"
running touch /tmp/balena/updates.lock gives me a permissions error whilst the permissions seem ok.
touch: cannot touch '/tmp/balena/updates.lock': Permission denied
ls -la /tmp/balena/
total 4
drwxr-xr-x 2 root root   40 Jul 17 08:56 .
drwxrwxrwt 1 root root 4096 Jul 17 12:57 ..
What could be the problem.
Since the particular container has access to the supervisor api i thought that maybe i could supervisor to manage these lockfiles via an api request and therefore circumventing the permission issue. However I do’t see any endpoint for that. Does one exist?
Don’t know what happened but a device restart solved the permission issues
Glad to see you got it to work @bas, we have not made any changes to the permissions of the mount in /tmp/balena. I assume you were running commands as root within the container. Please let us know if you see the issue again and we’ll investigate some more
